mlt34 said:I thought in one of your videos you showed that you sprayed the inside of the air breathing charger with waterproofing spray or something similar? That didn't help in the rain? Or maybe I'm mistaking...
mlt34 said:is the music change symbolic of your morale at this point in the trip? Also, you have mastered the 'walk and talk' :wink:
grindz145 said:More videos and my bike is back together! Put about 10-12 hours painting and swapping out the frame.
mlt34 said:Seems like the way out was characterized by your unbridled and youthful enthusiam while the way back was more like "G-d why did I do this..." :wink:
grindz145 said:http://instagram.com/p/ssP-WUNk2S/
Here is a pic of it this afternoon on lunch break. The frame is heavily gusseted in the front triangle, way stronger, and a little lighter. I'm not super happy with this geometry. A ground-up frame design will be in order at some point, but this was more just to get me back on the road again. I have to swap my Bottom Bracket out in order to get my big 52 tooth sprocket back on there too. The little 36 tooth sprocket just won't do.
mlt34 said:Have you considered custom triangle bags that might fit your frame triangle(s) better? I'm planning a cruiser frame w/ about 2kwh in the triangle and it's looking like its time for me to do by first custom bag. My sewing skills are decent (hey, tools are tools) but I'm not above asking my mom for help :lol:
ugn said:Wow, just discovered your thread and vlog! Nice work your doing here, love your videos
kudos said:You seem to have a custom cycle analyst box with buttons on the side or this a commercial unit?
Also, do you have a charging/wiring diagram of your setup, you were able to tell what charge was going into your battery with your CA, which I can only presume is done by charging by regen?
How this is achieved I have no idea, but is very cool and I'd like to know.
Cheers,
Kudos
dnmun said:yes, you would put the negative lead of the charger on the CA shunt lead where it goes to the P- on the controller. then the red positive wire from the charger goes directly to B+. the charging leads only have to be able to handle the charging current and do not have to be huge wires. so if you have 10A charging then 16AWG is adequate.
