Hi!
I also used to wind electric motors on my own, although they are for RX planes.
http://extremflug.de/seite075.htm
http://extremflug.de/seite076.htm
So, perhaps I can tell you a word or two about winding.
Generally, one should put as many copper a possible in a motor. Notice, that I do not say "many windings", but "much copper".
The number of windings and diameter of the copper wire is another thing.
With the total mass of copper in the motor being equal, one can either have more windings with less wire diameter, or less windings with more diameter.
Winding a motor with less windings at a bigger wire diameter, gives more speed and torque, but also requires a higher current.
Winding a motor with more windings at a smaller wire diameter, gives less speed and torque, but requires less current.
So, the best thing for you would be to take the motor as it is, and check the performance of your bike. If it goes too slow, get less windings with a bigger wire diameter on it, if it draws too much current and/or the motor overheats, less windings at a bigger wire diameter is the cure.
If the motor runs alright, but one wants to operate it with a higher voltage while keeping the same performance, one has to use more windings with smaller wire diameter.
Apart from that, do you guys know the concept of a push trailer?
Here is mine:
http://endless-sphere.com/forums/viewtopic.php?p=138625#p138625
Here are more ideas:
http://endless-sphere.com/forums/viewtopic.php?p=152093#p152093
The advantage is, that one is not restricted to the bicycle frame. It might be beneficial for you, as you use a lot of reduction chain drives. As a trailer can use a smaller wheel, which spins faster, you need less reduction, making things less complicated.
Also you can use a normal bike with it, and when the trailer wheel can freewheel like any normal rear bike wheel, you will have no problems pedaling home in a case of component malfunction or dead batterys, as there is hardly increased resistance.
Naeem, you rule! Continue your great work.
Greetings from Germany,
Julian
PS: Another idea might be to take car starter motors. These are durable, as easy to get as fan motors, and have low RPM and a high torque. Might be better than fan engines...?
What do the car-savvy people here think about that? Nonsene or worth a try?
