Metallover said:I repaired the connection. My throttle is still cutting out, I have to repair that too. Occasionally I get a !BMS! error, which leads me to believe that connector is flaky too. I have concluded the connectors on the Max-E are pretty poor in quality.
good to see you got one problem fixed. if you leave the BMS disconnect, do you still get the error?
the small 4-pin connector for throttle and brake seems to be poor quality. on mine the GND connection was bad, but i guess Adaptto buys them like they are (complete with wires). the other connectors are good Imo.
what i also noticed is the solder joints from the wires going into the display could be made better, and the adhesive foil with buttons does not stick very well on the display case. it makes a bump over the edge below the screen again and again and this may cause water can flow inwards. thats what i have seen on a very new controller with display V6.
btw, thanks for sharing pics. on some it looks like there is protective coating on the brain board. can you say more about this?
Allex said:Also, the new firmware will have support for PAS. But DC-DC mode will only be available in the unlocked version.
Nice. do you know where the PAS sensor will be connected to?
ridethelightning said:im now considering updating to the latest firmware version to get some new features, like the anti-theif,10k thermistor, updated charge screen etc etc.and hopefully to fix the glitch with the charge.
but am not 100% sure its going to work with no issues :|
anybody out there flashed the latest version and had any trouble?
any feedback much appreciated![]()
RC9d:
when doing autodetect, the motor suddenly starts to run very rough when it wants to spin up from slow to fast -> as far as i know this should have been fixed in this firmware, but unfortunately not!
antithief did not work properly -> turn wirerphc off, let the wheel spin free a few seconds (motor kV will change), turn it on again. this will make it work like it should.
