Allex
I always use a switch to protect others and the bike from those kind of misstakes. Only turn on display when I am on the bike.
dockers said:Got it working! The blue wire had cracked from the main board! Thanks so much for helping me get back on track!
up0 said:district9prawn wrote: "After trying a few firmwares I got it running smoothly on rc-9e in sine mode."
up0 said:Hi All,
I love what I read about the Max-E (more quiet, more efficient, BMS, great Display, etc ) and want to get one, but my next build will be a mid-drive.
Motor candidates are sth in the line of the Big Block, or Revolt 120 , Golden, or maybe sth completely Exotic
I am aware of the issue with the Max-E deriving the vehicle-speed-information from the motor and the implications this has (need for Speed sensor).
But from what I have read in various places, this controller does not "like" to run Mid-Drive motors.
Here Allex states: "They does not work well with middrives I heard."
Here: Andrey uses even stronger words: "use of middrive is definitely not recommended for noob! and future firmware upgrade will be necessary to support high RPM for middrive."
Yet some people are planning to use the Max-E with a Revolt e.g. here: "I use the rv-120 from revolt 45kV. I'm waiting for the max-e controller."
There seems to be no general issue that prevents outrunners like the Rotomax to run on a sine-wave controller
anda few posts up,. district9prawn wrote: "After trying a few firmwares I got it running smoothly on rc-9e in sine mode."
In this large community some more people must have tried to get the Max-E running with a mid-drive motor?
I would be happy if they could share their experiences here with some details!
Thank you already!
Ulli
district9prawn said:Also, the controller seems to handle regular reed switches poorly for the speed pickup. Doesn't seem to filter out contact bounce at all. Using a hall sensor just like you would for regen gets around this though.
crea2k said:Ok thanks I shall have a play with it, it works fine at 0 , but at three it surges on and off
Thanks !, I shall try thatmadin88 said:crea2k said:Ok thanks I shall have a play with it, it works fine at 0 , but at three it surges on and off
i also noticed this strange "on off on off" behaviour after flashing new firmware (it was another bike with cromotor not mine).
IMO its a bug in the firmware. I got it fixed after a reset and new autodetect. It also could help to swap the phase or hall sensor wires.
chucho said:I read sometime ago adaptto was going to include pass. If i buy now... in the future would it be possible to add this fuction to my Adaptto? Anyone now when this is going to be done?
