Allex
Keep up the good work doc, I knew that you would get there eventually, and soon even higher?
I'm hoping so...I realised recently I will be pushing this controller harder running on my HS4080 than I would have been running it with my HS4065.ridethelightning said:my bet is that will keep them fets a lot cooler ducky.
ridethelightning said:holy crap!!! did you seriously get 141kph?
not just no load speed??
thats INSANE!!!
There are voltage surges when the controller is operated at high phase currents (e.g. the higher the phase current the larger are the voltage surges – approximately 10V for each 100A of phase current for Max-E) which can blow up the power contour of the controller. It is highly recommendable in terms of in-feed to solder the capacitance of at least 6mF with a low internal resistance and also 0,01mF of ceramic/film capacitors low-esr.
Cowardlyduck said:Love your work Doc!
How many amps/watts would you say the Mini-E could sustain proportionally to the Max-E given your tuning?
Cheers
Good to know!ridethelightning said:im getting 5.4kw on the mine-e, and thats only with low c rate cells 8)
rtl, what firmware version are you running on your Mini-E? Currently, I have RC-9d installed and was told peak power was limited to 4.5kw in all versions RC-8(x) and above, witch is exactly what I'm getting, and upgrading to RC-9e will only take away some low end grunt by not allowing the controller to choose square wave starts. My battery should be capable of 6kw and easily delivers 4.5kw without heat..... as a matter of fact, I can run WOT for miles and nothing (controller, motor or batt) overheats!? Barely warm to the touch.ridethelightning said:im getting 5.4kw on the mine-e, and thats only with low c rate cells 8)
Doctorbass said:Cowardlyduck said:Love your work Doc!
Cheers
Well I think the Mini-E is different in term of number of mosfet and power ratio. This is difficult to say. The MAx-E is rated 10kW and mini E is 3kW... I got 16kW burst for a 10kW rated so it's 60% more.. but i'm not so sure the mini-E can do 60% more.. ex : 4.8kW.
Doc
skWarDog said:rtl, what firmware version are you running on your Mini-E? Currently, I have RC-9d installed and was told peak power was limited to 4.5kw in all versions RC-8(x) and above, witch is exactly what I'm getting, and upgrading to RC-9e will only take away some low end grunt by not allowing the controller to choose square wave starts. My battery should be capable of 6kw and easily delivers 4.5kw without heat..... as a matter of fact, I can run WOT for miles and nothing (controller, motor or batt) overheats!? Barely warm to the touch.ridethelightning said:im getting 5.4kw on the mine-e, and thats only with low c rate cells 8)
I ask because I'm seriously thinking of flashing RC-7b for my Mini-E as Allex and some of the other Max-E owners do on their units for higher power and speed..... I just haven't heard from any Mini-E owners that do this, except early in this thread when some (the OP) flashed RC-8 and noticed less performance?
ridethelightning said:ill try to check that for ya, the code that comes up on screen when it boots is the firmware for the display, not controller according to allex.
im not too sure how to check the firmware of controller. ill have a poke round...
Thanks guy's!ridethelightning said:ok. so did that: v1 rc7c
That's actually what I wrote to the SD Drive, and now the drive letter don't show up in windows explorer (I understand this is normal), so saves me a trip to Staples. I'll give 'b' a try...... It did write successfully, thanks for posting the translation @ 40 pages back, Allex! I'm sure I'm not the only one in this thread who appreciates all the really accurate knowledge you contributed to this thread and forum!Allex said:Dunno about rc7c, b is what I used and what doc uses now.
