Well, tried to flash my firmware again with a third (256MB Panasonic) SD card and got the same Firmware CRC error.
What's also interesting is when I try and flash just the controller, it says incompatible firmware...I double checked and I did download the MINI-E firmware. If I try and flash just the screen it comes back with the same CRC error above.
Boestin said:
I couldn't find in the manual (on page 1 on this thread) if the sdcard should be formatted
So I reckon you should try to format the card to fat32 and try the whole process again.
Thanks Boestin. Unfortunately I don't think that's it...my first card was FAT, and the last 2 were FAT32, but still didn't work.
Hyena said:
Re: adjusting the values, I notice both seven and obhse use ind timing of 366uS but on mine the numbers jumps in big blocks (from 334 to 394) and the same with the angle corr (jumps from 0.4 to 1.1 and then up 0.7 at a time) Is this normal ?
Good to see you've joined the Adaptto club Jay.
I think those values do jump like that normally as mine do the same. I also saw them change increments too. Previously I could only set my pwr timing to 51, etc...now it goes to 53, etc. I'm not sure what caused the increments to change though...sooooo many settings
Hyena said:
BTW, the fact that the screen takes ~3 seconds to come on when you turn the key is a little disconcerting when you first power it up. After spending all day working on the bike and splicing multiple wires to turn the key and see nothing happen is the worse! :lol:
I hear you...there's been a few times where my hearts stopped after messing around with wiring etc and the screen feels like it takes an eternity to come alive.
Also, is the screen meant to show a firmware version when it turns on? Mine just flashes a line before going straight to the home screen...is that normal?
I also realised that because my Mini-E is not registering any kind of Watts/amps, it is also not limiting the power in any way. That is why my BMS keeps tripping, and that is why it has INSANE torque! Crazy thing is, it still doesn't get hot at all. I've only done minimal testing around the backyard so far, but it seems my heatsink + fans cooling solution works very well. With them running, and me going nuts (=hard accel - regen - hard accel, etc) around the backyard, I could not get the controller FETs to break 30C and the motor 50C.
Unless anyone has any insights on the above issues with my controller, I think I might have to email Adaptto.
Cheers
