Hyena
It's not specific to every single motor is it ?Allex said:I am trying to tell people that Manual tuning is the only thing that really works
Ie if you have it running perfectly on a say a mxus 3T then the next guy running the same motor and voltage should be able to use the same settings ? Or is it precisely matched to each motor ?
I've had hall failures in 2 of my setups running sabvotons. On one of them it runs fine after replacing the hall without any reprogramming, on another the hall seems to be slightly out of alignment and if I pin it at full throttle for more than a few second the controller shuts down will gives a hall error. It otherwise runs perfectly fine and smooth. So maybe they ARE super sensitive to exact hall position ?
