GmagNeato said:brumbrum said:GmagNeato said:@Brum might have an issue with channel 1 cell. Could be going up in voltage quickly due to reduced capacity. Then when the charge current stops it comes down quickly to meet the others due to high self discharge. May want to check the internal resistance and overall health on that one. Is it in an older pack?
Also wanted to say that with firmware 9G2 my BMS continues to balance after the charger has completely charged the battery and I've unplugged the charger from the wall. I'm assuming it will do so until the top cell reaches the BMS balance voltage I've got set? Nice that it just quietly continues to balance until I go for a ride and bring the voltage down. I've left it this way for about 2 hours now and the delta has gone from .021 to .018. I hope this function hasn't changed on 9G4 which I'll be flashing to once my SD card arrives tomorrow.
Thanks for the heads up, the cells are actually pretty new, so i will keep an eye on things.
What do you mean when you mention 'delta' , is this a term for the cell voltage difference or is it a measurement for something else that i can find in my adaptto display?
So I've left my bike to balance today with the charger completely removed. BMS is still working and delta has gone down so far to .013!This is from .021 to .013 over a period of maybe 5 hours. Whereas in the past with my charger plugged in all night long, which I've done 3 or 4 times now, there has been almost NO change in the delta when I check it the next morning, even though it reached the balancing threshold and the BMS is functioning before I even go to bed. The best I've seen doing it this way is about .019v delta. This is confirmation to me that the charger is impeding the balancing process, at least in my case. So from now on I will be using the charger to get it up to 100%, and then removing it and letting it balance overnight. This is actually a much better method IMPO anyway, as the charger doesn't continue to stay plugged in and running all night.
I would like to second this above statement about balancing without the psu switched on. When switching off my psu and the bms is set to be in a state of balance the bms does indeed carry on flashing its lights and carries on balancing down the upper cells. What a great find! Big thanks to Gmagneto!
Thanks also Allex for the heads up on the cell leakage, i will be, and have been, keeping an eye on individual cell movement as you can probably tell from my series of posts over the past couple of days lol!
