E=IR said:What do you consider the maximum width for solar panels on a trailer? Perhaps the same width as the handlebars?
KarlJ said:I worked for Boeing many years and I've drilled millions of holes in the stuff.
KarlJ said:RE Carbon fibre dust - under the microscope carbon is not at all like asbestos and does not have a hook which asbestos does hence the human body deals with carbon fibre dust just fine.
KarlJ said:RE electrical conductivity is very very low, the resin is nil and the dissimilar materials you mention is due to the hydroscopic nature of carbon and it does hold moisture, separation of aluminium and carbon in the aircraft industry is achieved with paint on the aluminium surfaces and polysulfide sealants which keep the moisture out of the joints which would otherwise gather moisture whilst the aircraft temperature changes rapidly during climb / descent. Terrestial much less of an issue and paint of surfaces in contact with each other should be sufficient.
solarEbike said:Mostly, I’m breaking radio silence to share an interesting development that’s come to my attention recently. LightLeaf Solar is a new Canadian startup offering custom-made solar panels uniquely suited for use on an ebike: good weight/power ratio and integrated with a stiff structural panel so they’re self-supporting.
Cephalotus said:Do you already have an indiction about the price they do ask per Wp and how much customization is available?
Cephalotus said:Do you happen to know about builders of custom made lightweight solar panels within the EU?
Cephalotus said:My latest design idea is to us my six 50W panels at roughly 55cmx56cm (depends on how much I cut of from the sides) in a /\ configuration with 3 panels on each side, that can also change into a total / or \ or _ _ configuration.
bakaneko said:Damn, I just checked solar panel prices on eBay and they are real low compared to when I built my 100W solar ebike like a couple years ago.
solarEbike said:While any of these might be fine for casual prototyping on a limited budget, keep in mind some of the risks and hidden costs of buying from the lowest bidder on eBay. The anonymous, ephemeral nature of the sellers' and manufacturers' identities creates an incentive to exaggerate panel weight and output.
A pyranometer is invaluable for such testing - and they are relatively cheap ($140 or so.)bakaneko said:I mean the solar panels I got from eBay met the output specifications under ideal conditions - solar noon, no clouds, summer, optimal tilt. The rest of the time it was at like average a bit above 50%. Not sure how the "premium" ones compare under the same conditions.
Keep an eye on Craigslist, LetGo, ect. for used recumbents. Most don't have suspension, but I was able to get this Optima Lynx for $280. Swapped out the wheels and got a front suspension fork to work!bakaneko said:Too bad recumbent bikes are still a billion dollars. LOL
thundercamel said:Keep an eye on Craigslist, LetGo, ect. for used recumbents. Most don't have suspension, but I was able to get this Optima Lynx for $280. Swapped out the wheels and got a front suspension fork to work!bakaneko said:Too bad recumbent bikes are still a billion dollars. LOL
wturber said:<sarcasm> OTOH, ebay seems to be the place where you can find the most high tech of 18650 cells. One need not look far to find 18650 cells that have 6800, 7900, and even 9900mah capacities. So clearly ebay must offer the leading edge of high tech componentry</sarcasm>
I buy plenty from ebay. And there can be excellent values. But you really do need to shop carefully and hopefully rely on feedback about sellers and what they sell from reliable third parties.
bakaneko said:I mean the solar panels I got from eBay met the output specifications under ideal conditions - solar noon, no clouds, summer, optimal tilt. The rest of the time it was at like average a bit above 50%. Not sure how the "premium" ones compare under the same conditions. I mean if you are going to pay double just for 60% versus 50% its not worth it to me.
billvon said:A pyranometer is invaluable for such testing - and they are relatively cheap ($140 or so.)
bakaneko said:I don't just randomly buy cheap solar panels from eBay hoping for the best. I look for domestic importers/manufacturers that use eBay as another store front and have a review history online. Mine was at about $1 per watt.
bakaneko said:Its been a while but I know there is technologies that increase performance at non optimal tilts, which would be worth considering paying more.
bakaneko said:I mean I haven't seen any solar panel that perform at 100% without the optimal tilt and conditions.
bakaneko said:The 150-200W panel is going to be a beast..
Cephalotus said:IR Pictures can be made easy and cheap with a dark room, a suitable DC power source to reverse power the solar module (bypass any diodes) and an old Sony F717 or Sony F828 with s small magnet to put it into "nightshot" mode.
Cephalotus said:...a suitable DC power source to reverse power the solar module...
solarEbike said:This is electroluminescence, right? Driving current trough the panel in reverse causes each cell to emit infrared light which is picked up by the Sony camera. The magnet is a trick for disabling the IR filter in the camera. The cracks in your image are micro-cracks which are otherwise invisible to the naked eye under normal lighting conditions?
So, you all might be wondering what is the significance of these cracks if the panel still puts out 50W? Per their own datasheet, "When a SunPower cell does crack, the backside copper metal foundation keeps the cell intact and maintains a high power output."
Areas with cracks create hotspots which soften the plastic encapsulation materials around them, making them more vulnerable to additional damage in that area.
How do you figure out what is suitable for a given solar module without damaging it? I'm getting curious to try this out.
Cephalotus said:Here is maximum output of Jack Butlers solar array... I don't know, but I assume that the solar panels Jack Butler used did have significant performance problems at the end. When searching for a picture of the mounting of his solar panels I noticed that he crashed his bike.
solarEbike said:Overall, the decreases in peak daily solar watts seem too high to me to be explained by panel degradation alone. I remember Justin commenting on the fact that it was very rainy during the second half of the trip. If it was overcast all day, the daily peak would be much lower. Maybe that's part of it?
I posted the shared spreadsheet with all the imported daily data here. Anyone can download it in Excel or OpenDocument format using File > Download. If you log in with a Google account, you can use File > Make a copy to save your own copy which can then be edited in the browser: https://docs.google.com/spreadsheets/d/1W9OyghiQpFIGjzOiGsGe0LiDR2yYv79qxzgNIZ2uDFs/edit?usp=sharing
Cephalotus said:Best way to analyse this now would be to make IR photographs of the used modules.
Cephalotus said:For peak power you need full sun, obviously. But actally partly cloudy days provide the maximum peak solar power, when sun is reflected on white clouds (this can increase power up to 20% compared to full clear sky) and modules are still cold from the last cloud.
Cephalotus said:Did you find out the highest daily Wh/Wp for all riders so someone could guess what would be possible under good to ideal solar conditions. I could do it myself if I would be able to find out the installed solar power for each rider.
