Great work!!CiDi said:I checked what happens when the display is switched on:
Off: VCC=0V, P+=Battery+, Can=off
Press the power button for display on: VCC=0V, P+=2.2V, Can=on
Display on: VCC=Battery+, P+=2.2V, Can=on
Release the power button: VCC=Battery+, P+=4.5V, Can=on
Press the power button for display off: VCC=Battery+, P+=2.2V, Can=on
Display off: VCC=0V, P+=2.2V, Can=on
Release the power button: VCC=0V, P+=Battery+, Can=off
For power on, it is probably sufficient to connect P+ to GND, but in this way there would be no voltage to power the display, for this reason it leaves a residual voltage of 2.2V which becomes 4.5V once the phase has taken place.
If i connect the BESST interface, the voltage on P+ remains 0V and the controller turns on.
I am attaching the file of the can telegrams in the power-up phase:
Thanks. I don´t know if you can add all this information to the repository while you add it to here also.CiDi said:If it helps, these are photos of the Bafang DP241C display.
casainho said:Thanks. I don´t know if you can add all this information to the repository while you add it to here also.CiDi said:If it helps, these are photos of the Bafang DP241C display.
A developer told this:
I know 2 mechanisms.
- The normal well known UART diplays: the display switches the blue wire to battery +. The blue wire supplies the voltage regulator of the controller.
- On the CAN display I analyzed (Ananda) the on button on the display pulls a wire (blue, it has battery voltage from a pull up resistor) to ground. This is the signal for the controller to switch on a 36V line (red) as supply for the display. If the controller gets no valid CAN messages from the display, it switches off the 36V display supply after a few seconds
CiDi, is there a sequence of CAN messages when turn off the controller?
Maybe you can join this telegram channel for Bafang M500/M600 development:
https://web.telegram.org/z/#-1748500567
Would be great if we could write a table with all know CAN IDs... there are a good number of them on the turn on and turn off that are not documented....CiDi said:I attach the can messages file when you turn off the display.
casainho said:Would be great if we could write a table with all know CAN IDs... there are a good number of them on the turn on and turn off that are not documented....CiDi said:I attach the can messages file when you turn off the display.
For the system of an Ananda Controller and the Bafang Display, I wrote a code some time ago, that emulates the controller communication. You can send speed, power etc to the display with it. Of course you need the other way round, but perhaps it helps a little. I still don't know, if the protocol is the same as the one from the Bafang controllers.casainho said:if someone could help, would be really important!!
Thanks. I use CAN at work and I use Linux CANUTILS softwar. On hardware side, I use the most cheap USB CAN adaptor from the AliExpress. CAN on Linux is straight forward to do that tasks you did mention - and no need to buy any software, including that CANUTILS is OpenSource and you can reuse his source code for your application.Tomblarom said:I recently done CAN reverse engineering of other popular ebike systems. It's mandatory to have a gateway device for this job, because you want to ..
- know which messages came from which side.
- filter certain messages for testing.
- trace/record and play back messages.
Here are a few options I know:
- PEAK PCAN: mighty software, expensive
- CAN-Hacker: basic software, fairly cheap (russian, unfortunately currently offline..)
- Toomoss UTA0402/UTA0403: not tested, fairly cheap
- DIY STM32 CAN-Hacker / FD version: not tested, seems reliable, software may be limited..
We can use Vector CANdb++ for this. It's a software to generate and edit .dbc files, a standard for CAN database. OpenSource Software like CANgaroo also supports it!casainho said:Would be great if we could write a table with all know CAN IDs
Your Telegram link does not work.casainho said:Maybe you can join this telegram channel for Bafang M500/M600 development:
Try this one: https://t.me/+O5GciLgdbBc0ZGRkTomblarom said:Your Telegram link does not work.casainho said:Maybe you can join this telegram channel for Bafang M500/M600 development:
Sure I also have CANable hardware + CANgaroo that's SocketCAN compatible. It costed me a whole day and I wasn't able to properly setup a CAN gateway using cangw + python, wherefore I gave up and bought a CAN-Hacker. - Anyways. Offtopic! Let's have this coversation in Telegram ..casainho said:CAN on Linux is straight forward to do that tasks you did mention - and no need to buy any software, including that CANUTILS is OpenSource and you can reuse his source code for your application.
Tomblarom said:It's mandatory to have a gateway device for this job
I think the idea is to have another option to connect some CAN device, for instance the brakes could also be CAN!! See that the torque sensor is CAN. On the M365, the brake signal connects to the display and then the brake sensor data flows to the motor controller as a digital value (on this case over UART).Tomblarom said:Can somebody explain this to me, about the wiring harness of the M500/M600? Why does the brake plug need CAN high!? (I made this layout by measuring)
casainho said:Updated the EasyDIY display schematic.
The CTRL pin is put to GND when pressing the power button on the remote. Then there is a voltage divider with 2 resistors, to change the battery voltage to max of 3.3V (including a 3.3V zener diode as a protection) to avoid that signal to go over 3.3V, that is the limit of the microcontroller pin. The microcontroller will then read the power button state by reading the voltage with an ADC.
I would like to get feedback, does anyone things this is wrong? or suggestions for improving??
As I said: I measured and got both versions (with/without throttle) for comparison. Programm is Fritzing.CiDi said:Where did you get this wiring diagram?
Tomblarom said:As I said: I measured and got both versions (with/without throttle) for comparison. Programm is Fritzing.CiDi said:Where did you get this wiring diagram?
Still, I don't understand how the cut-off works.. Can't imagine the put CAN high only on there.. Why would you?
