BeachRider2016
here's the data after I tried flashing once more with 311 file
After flashing it no longer connect to Bafang Configuration Tool as well.
"Checking target MCU ...
MCU type: STC15W4K56S4
F/W version: 7.3.4T
Current H/W Option:
. Current system clock source is internal IRC oscillator
. IRC frequency: 18.427MHz
. Oscillator gain is HIGH
. Wakeup Timer frequency: 36.891KHz
. Do not detect the level of P3.2 and P3.3 next download
. Power-on reset, use the extra power-on delay
. RESET pin behaves as I/O pin
. Reset while detect a Low-Voltage
. Thresh voltage level of the built-in LVD : 2.78 V
. Inhibit EEPROM operation under Low-Voltage
. CPU-Core supply level : 2.78 V
. Hardware do not enable Watch-Dog-Timer
. Watch-Dog-Timer pre-scalar : 256
. Watch-Dog-Timer stop count in idle mode
. Program can modify the Watch-Dog-Timer scalar
. Do not erase user EEPROM area at next download
. Do not control 485 at next download
. Do not check user password next download
. TXD is independent IO
. TXD pin as quasi-bidirectional mode after reset
. P2.0 output HIGH level after reset
. Testing time: 2015-12-16
. MCU type: STC15W4K56S4
F/W version: 7.3.4T
Adjusting frequency ... [1.484"]
Adjusted frequency: 18.427MHz (-0.026%)
Re-handshaking ... Successful [0.110"]
Current Baudrate: 57600
Erasing MCU flash ... OK ! [2.703"]
MCU ID : F5280000007829
Programming user code ... OK ! [14.813"]
Programming OPTIONS ... OK ! [0.032"]
H/W Option upgrade to:
. MCU ID : F5280000007829
F/W version: 7.3.4T
. Set frequency: 18.432MHz
. Adjusted frequency: 18.427MHz
. Trim error: -0.026%
Complete !(2019-06-09 19:10:25)
F/W version: 7.3.4T
Current H/W Option:
F/W version: 7.3.4T
F/W version: 7.3.4T
