Kiriakos GR said:Amazing Bafang horor stories, so to admire their engineering perfection :lol:
http://endless-sphere.com/forums/viewtopic.php?f=28&t=65711
http://endless-sphere.com/forums/viewtopic.php?f=28&t=67228
eMax said:I certainly intend to get some real data across for you guys. I will make some initial assessments with the controller provided but will move over to CA3 and infineon controller fairly quickly. I guess the advantage of an external controller and PAS is that this change can be made very easily.
The BEWO definitely has a quality feel to it, probably a reason why it's marginally heavier than a BBS01.
Interestingly I was provided 2 adapters (one for 68mm, one for 73mm). I will wait till I install but from what I can tell using either of these adapters will not affect the axle length, so the q-factor will not be ideal on one of these options.
tomjasz said:I used the foe list. No longer appears on my screen, and since there's never anything worthwhile, why not.
Kiriakos GR said:By the way you are obligated to post a picture of your received goods, plain words has no value to me, never had.
Kiriakos GR said:Can you measure the exterior diameter of just the electric motor ? (use a flexible tape and place it all around it , metric system is my preferred) :wink
Kiriakos GR said:If not asking too much I need also a copy of the 350W nominal motor documentation, electrical specifications and rotation per minute.
I hope to contact me by PM, so to get that by email.
The final plan is to create a new topic exclusively for BEWO KIT owners.
So no one to have to read 10 pages so to get 10 worthwhile information's about these 250W & 350W KIT.
Kiriakos GR said:I can not help it, every motor working out of specifications reminds me a crime scene.
what you should not fear is the reduction gears, they are not made of plastic. :lol:
eMax said:Not the response I expected. I am using the Cycle Analyst to gather information about the motor. Mainly efficiency. As I said I will be matching the specification of the controller that was sent to me.
I will also be testing with the regular controller of course.
eMax said:Have been busy this afternoon. Have made myself a custom plug to run the motor with a Cycle Analyst 3 and Infineon 20a controller. It was fairly simple, just match the phase cables using the correct colours. The controller I have chosen has phase mapping so even if you get it wrong it makes in right.
Have given it a few quick spins. The chainring is 46T and the rear gear is a Shimano Alfine 8 speed. Some promising performance, unloaded of course. I will be using the recommended power and current settings when doing a real test tomorrow. The controller that came with the kit is also rated at 48v 20a (I was initially told this was a 36v kit).
Here is a short video...![]()
http://youtu.be/dYnLma1Vx9E
