dogman said:
6x10 on 18s should work really nice.
Last night and this morning I reread my build thread here.
I want to thank dogman for the many helpful postings here and elsewhere on this forum. The same goes to all other helpful contributors to this thread and ES.
Based on everything I have read it looks like 18S on a 6x10 hub should be good for what I'm doing. Great torque and power up to the mid 20's mph. Torque falls off above that but top speed around 30. That is plenty. Good efficiency for the hills and long commute. I may even set the CA limit to 23 or so. Have to see how it goes. Thanks to methods for making these available again.
We've come a long way. The project is taking shape. We've got good brakes, tires, wheels, spokes, motor, torque arms, batteries, controller, throttle, mirror, shifter.
Issues at this point:
Rear derailleur not working well. Need to adjust or change something. I have not gone through the full adjustment yet so it may work fine after that. If not perhaps finding a freewheel that goes to 28 instead of 34 would be prudent. Do I really need a 34 tooth gear on this bike?
Battery mounting. nuff said at the moment.
BMS. Working on that. Short term just be careful and use RC chargers. Medium term add LVD. Long term something homebrew with microprocessors.
Chargers. RC for now. Improve when microprocessor BMS is working.
Fenders. Not fun, but probably necessary. Even in nice weather the pavement is wet in some spots. Anything good out there?
New wheel hardware. Need some washers. And another torque arm. And remake the soft alum torque strut.
Wiring. Need 4mm connectors (out of stock), fuses, probably a few other bits. May have a keyswitch. Some wire on the way.
Handlebar tape. Or grips, but tape sounds like a more flexible solution.
Sort out the kickstand mount. (Got a new dual leg model but concerned that it will crush the tubes).
Clothing. Have new helmet, need better gloves and probably riding pants. Something that doesn't look lycra.
