Now for what I find the most difficult part of building the motor, the glueing of the coils.
Basically what we want to do is wind a coil soaked in glue, transfer it to the coil plate, clamp
it in place and leave it to cure for 24 hours. After that we need to remove the clamp without
destroying the coil.
I've tried different types of glue and ended up with epoxy. Next to being strong, the glue
needs to cure by means of a chemical reaction, NOT by means of the evaporation of a
solvent. Because the whole structure will be clamped tight the evaporation of solvents is
not possible. I've tried specialty acrylic glass glue but the solvent did not evaporate, leaving
me with a goo-ie mess even after 48 hours of 'drying'. Epoxy gives a beautiful and very strong
result, so I've stuck to epoxy.
I let the glue cure at room temperature, so the strength is around 1200N per cm squared.
The glued area is a circle of 4cm diameter, 0.5 cm high so an area of roughly 6 cm^2.
7200N is roughly 720 kg, strong enough I would say
. I've thought about heating
the glue to cure it faster and stronger. I'm a bit worried though about the acrylic glass expanding
slightly under higher temperature, leading to cracking when it cools down again. But passing
a current through the epoxy soaked coil would make heating easy...
Ok, now, to make sure the wooden disks used to clamp the coil in place doesn't stick to the
epoxy I conver them in what in Holland is called 'boeklon'. Its a self-sticking thin plastic sheet
material used to cover and protect books. It is sold at book and office supply stores. Lots of
library books are covered in this stuff.
First prepare the coil plate.
