I asked lyen to set my controller to 74volts. I wanted to try to test the wheel with my 31v power supply but nothing is happening....
itchynackers said:The red power wire needs to be tapped into the battery voltage all the time when you want the bike to run, not just a temporary push. I wired mine to battery + permanently, with an emergency cutoff switch on the handlebars. That way I can pull the switch, cutting power to that thin red wire if I want to. Haven't had to use it yet.
itchynackers wrote:The red power wire needs to be tapped into the battery voltage all the time when you want the bike to run, not just a temporary push. I wired mine to battery + permanently, with an emergency cutoff switch on the handlebars. That way I can pull the switch, cutting power to that thin red wire if I want to. Haven't had to use it yet.
you mean I need a On/off switch and not just a press switch to activate?
thanks a lot
wesnewell said:I don't know what you *need*, but with a single hyperion 1420i you can charge all the cells at once. You just need to reconfigure your 20s2p pack to a 10s4p pack for charging. I guess you could also parllel charge them all at once too, but it would seem easier to do as a 10s4p pack.
Sure you can. You will just need a couple of 5s parallel balance adapter cables.Karl said:But I wont be able to balance while charging tho?
Usually from tppacks.com but the website is down so, pm GGoodrum here on ES for both hyperion and leads.Karl said:can you show me where I can purchase those?
Karl said:I thought a 9c came with hall sensors... they dont.. I hope that wont cause me problems with lyen's controller...
mike662 said:Good stuff! I really like the laptop backpack idea, it's very stealthy and can easily be worn under a jacket or even under another backpack! Could you take a photo of it with the batteries inside when you get your batteries?
mike662 said:Would you mind saying where you got the backpack from? I'm thinking of getting one from ebay: http://www.ebay.ca/itm/New-Laptop-Backpack-Notebook-Back-Bag-10-15-Laptop-/320727139794?pt=UK_Computing_LaptopAccessories_LaptopCasesBags&hash=item4aacd3c5d2#ht_6575wt_997 but there might be cheaper ones somewhere
