s-petersen
1 W
I'm building my first e-bike, and I am looking for better solutions.
Here is the battery, it is 36v 10AH A123 ANR26659M1B LiFeP04 3.3v 2500mAh in a Server Pack
The battery is larger than most, but it will not burst into flames. The only place on the frame it fits is on the front of the down tube, or if there is some kind of rear rack that fits my bike.This is the bike: My legs are not long enough to have the seat any higher than the lowest setting, so a rear rack is not easy to find. The kit is a 1000w Voilamart front hub motor. I will not be going much over 20mph, and the paths are black top, so no severe riding, I'm just riding for being outdoors, and some exercise, with some help om hills. I know there are some out there that will say because it is not a high dollar bike, it is junk, but it is what I have. I am looking for suggestions for a back rack for the battery, or if I mount it on the front a slide mount for the battery that can be latched so the battery does not fall off. I also need a shifter control for the handlebar for 7 speeds, currently the left and right shifter controls are a twist type and the right one will have to be changed to a thumb type because the motor throttle will have to replace it. and the last question the crank has to come apart to add a pedal sensor, can it come apart without special tools, or do I need a puller of some kind? I bought this bike 25 years ago, and rode it a few times, but things changed, and opportunities to ride no longer happened, I just retired, and now have time to start riding again, I am really out of shape, and the 350w e-bike I fixed does not have enough power for the worst hills, the ones I need help for.
