spinningmagnets
100 TW
Here is a link to the endless-sphere wiki section on chain: http://endless-sphere.com/w/index.php/EBike_DriveSystems_Chain
Pic courtesy of Whippermann.
http://www.gizmology.net/sprockets.htm
Notes on Sprockets and Chains
A sprocket is a toothed wheel upon which a chain rides. Contrary to popular opinion, a sprocket is not a gear.
Chain Construction
Chains have a surprising number of parts. The roller turns freely on the bushing, which is attached on each end to the inner plate. A pin passes through the bushing, and is attached at each end to the outer plate. Bicycle chains omit the bushing, instead using the circular ridge formed around the pin hole of the inner plate.
Chain Dimensions
Chain types are identified by number; ie. a #40 chain. The rightmost digit is 0 for chain of the standard dimensions; 1 for lightweight chain; and 5 for rollerless bushing chain. The digits to the left indicate the pitch of the chain in eighths of an inch. For example, a number 40 chain would have a pitch of four-eighths of an inch, or 1/2", and would be of the standard dimensions in width, roller diameter, etc.
The roller diameter is "nearest binary fraction" (32nd of an inch) to 5/8ths of the pitch; pin diameter is half of roller diameter. The width of the chain, for "standard" (0 series) chain, is the nearest binary fraction to 5/8ths of the pitch; for narrow chains (1 series) width is 41% of the pitch. Sprocket thickness is approximately 85-90% of the roller width.
Plate thickness is 1/8th of the pitch, except "extra-heavy" chain, which is designated by the suffix H, and is 1/32" thicker.
ANSI Standard Chain Dimensions
Chain#___Pitch__Roller Diameter__Roller Width__Sprocket thickness__Working Load
8mm_____8mm_____4.7mm______ 4.8mm_______XXX_____________XXX
25_______1/4"______0.130"_______1/8"_________0.110"__________140 lbs______pitch = 0.250" or 6.35mm
219______5/16"_____0.180"_______0.183"_______0.160"__________Xtra strong___pitch = 0.312" or 7.77mm
35_______3/8"______0.200"_______3/16"________0.168"__________480 lbs______pitch = 0.375" or 9.52mm
41_______1/2"______0.306"_______1/4"_________0.227"__________500 lbs______pitch = 0.500" or 12.70mm
40_______1/2"______0.312"_______5/16"________0.284"__________810 lbs______pitch = 0.500" or 12.70mm
Bicycle and Light Motorcycle Chain Dimensions
Chain#_________________Pitch____Roller Diameter__Roller Width____max sprocket tooth thickness
Bicycle, 9-speed or more __1/2"_____5/16" 0.315"_________xx__________0.069" (1.75mm)
Bicycle, with Derailleur___1/2"______5/16"_________3/32" (2.38mm)___0.087" (common bicycle chain size)
Bicycle, no Derailleur_____1/2"______5/16"_________1/8"_(3.18mm)___0.110" (Fixie, BMX, single-speed)
41_____________________1/2"______0.306_________1/4"_____________0.227"
410_____________________1/2"
415_____Heavy Duty______1/2"_____0.315"_________3/16"/0.188"______0.168"/4.3mm
420_____________________1/2"______0.315"_________1/4"/0.250"_____0.227"/5.8mm____link sideplate thickness 1.8mm
425_____Heavy Duty______1/2"______0.315"_________5/16"___________0.284"/7.3mm
428_____Heavy Duty______1/2"______0.335"_________5/16"/0.313"____0.284"/7.3mm____link sideplate thickness 2.0mm
In the SAE chain-naming convention, the first digit "4" means 4/8ths of an inch, which is commonly called 1/2"
http://www.cometkartsales.com/store/chains/chains.htm
http://www.staton-inc.com/store/pro...eewheels_Sprocket_Adaptors_Chain-1047-47.html
Small drive sprockets should be at least 11T or larger to avoid the noise of Chordal action and the polygon effect: http://endless-sphere.com/forums/viewtopic.php?f=28&t=18823&start=50#p276230
Chain Construction
Chain Dimensions
