boppinbob
I have a sensor less HS 3540 with a 7240a Crystalyte controller and an APM display. You can change voltages and amp setting on the controller with the APM. I have 4 zippy 5s8Ah packs in series for 72v 40amps, which is what I normally set it to. Today I reduced the voltage to 60v and 30amps. Does that increase the mileage I can get on a charge. I didn't run it long enough to find out. I hope I don't kill the controller testing it like that. It might be that it only reduces the lvc. I had to work today so I didn't test it on the road for long enough to find anything out. Next week I'll give it a better testing unless someone in this forum thinks I'm harming the controller or motor. Regards, Bob Pate
