Common pack design mistakes, how to avoid?
Buk___ said:
But what evidence is there than these arrangements are "perfect"? Or even "better"?
If they result in each cell seeing the same resistance to the discharge leads then they are "perfect". If they fail to achieve this despite a labyrinth of nickel strip then the layout is a folly. A complex design needs to justify itself with increased functionality else it's just making hard work for yourself.
Your latest analysis beat me to this point - I assumed the layout in question was supposed to achieve equal resistance to all cells. It seems it doesn't and yes, you have to ask "how much better is it than a simple layout? What is the real advantage?". It becomes subjective and all we can say is current should be as good as reasonably practicable. Much like how balanced should your pack be? 0.1V? 0.01V?
Hm. I don't think there is anything "subjective" about it.
This is both an empirically measurable property, and a something that can be characterized according to well known and well-defined physical laws; and thus reasonably accurately simulated.
But graphical representations of what 'looks right' are fiendishly deceptive when it comes to high order parallel resistances.
Subjective in that you must decide what is acceptable for a given application. Whereas with equal resistances all you can simply say "job done".
You have no argument from me there.
Hello and sorry I haven't replied for a few days. Really busy at work! :)
I have created a demo for the various connections seen on the SmartGauge page:
View attachment 15P connections demo.txt
This shows two things:
1) The SmartGauge website is right and the first two types of connection are just a pain for the cells.
2) I have made a huge mistake with my schema. I should never go with 15P. It cannot really work with that balancing configuration.
After working a bit with the falstad circuit simulator, I have now come to the conclusion that I have to go with a 13S16P pack. The 'perfect' connection is the following:
However, I still have some changes in mind regarding the connecting strips. There is some significant voltage drop because of the total resistance on each cell. This can be helped by using nickel and copper strips or nickel strips and copper wires. I am currently making the calculations and I'll be back with my results as soon as possible. :wink:
So, the configuration I am going forward with is the 13S16P with the cells connected as shown in the following images:
The connections between cells next to each other will be done with spot welding 7mm wide 0.15mm thick pure nickel strip. Thus, all cells will be connected with the nickel strips in pairs in the first place. Then, the 3.6cm length connections, connecting second with fourth or first with third will be done with spot welding a 10mm wide and 0.1mm thick copper strip that will be split right in the middle for the spot welder to do its job. Finally, the quadrants (rows in the images above) will be connected using a 12AWG wire and old fashion flux welding.
The final result should be a 48V 13S16P battery pack with each cell facing 2.073mOhms of resistance because of the above connections. You can see the circuit in practice using http://www.falstad.com/circuit/circuitjs.html with the text here: View attachment Perfect 13S16P pack.txt
I am looking for both feedback on my attempt and your own numbers to compare if possible.
Feeling excited now! Looking forward to actually finishing the pack and see the practical results. :D :D :D
So, I have finished my first 16P pack. It went better than I thought. I only used spot welding @40A for nickel strips and @60A for the split copper strips. I only need to solder a wire for the positive and a wire for the negative pole of the pack to finish it. And... do it 12 more times of course! :?
You can see the result here:
So, the steps I followed were:
1) Spot weld 16 cells in pairs using 25x7x0.15 mm pure nickel strips
2) Connected pairs of cell pairs in a row by spot welding 1st to 3rd cell on positive end and 2nd to 4th cell on negative (Positive of 2nd and negative of 3rd are covered by electrical tape). Used 40x10x0.1 mm pure copper strips split right in the middle to form two 40x5x0.1 mm parallel strips.
3) Used hot glue to stick the four fours of cells and have one solid pack.
4) Spot weld one small 1cm piece of nickel strip on the positive of the 2nd cell of each row and on the negative of the 3rd cell of each row.
5) On the positive end, I spot weld 2nd cell of row 1 to 2nd cell of row 2 as well as 2nd cell of row 3 to 2nd cell of row 4, using 25x10x0.1 mm copper strips split in half to form two 25x5x0.1 mm strips. Also used the same strips to connect the negatives of the 3rd cell of row 1 to the 3rd of row 2 as well as the 3rd of row 3 to the 3rd of row 4.
6) On the positive end I covered with electrical tape the 3rd row and on the negative end I covered the 2nd row.
7) Spot weld a small 1cm nickel strip piece on the positive end of 2nd cell of row 2 as well as the 2nd cell of row 4. Then, I spot weld a 40x10x0.1 copper strip (split in half again) on top of those cells.
8) Like step 7, I have spot weld a 1cm piece of nickel strip on the negative end of 3rd cell of row 1 as well as the 3rd cell of row 3. Then, I spot weld 40x10x0.1 copper strip (split in half again) on top of those cells.
That's it! :D It might have taken me some time to do (And it will take a long time to do it again for 12 more packs), but I am very pleased with the result and myself! I am proud I figured out a way of spot-welding copper using my cheap £100 spot welder! :D :D :D
Has anyone on here now tried any of the liquid/spray on based protective coatings for your battery packs?
Like the stuff they have on TV that keeps a boat afloat with a screen door as the hull? Lol... Not that I've seen, nor do I think it's the best idea. If you're planning on spraying it directly on the batteries I'd think it'd make it nearly impossible to do any maintenance on the pack if needed...plus it might mess with the CID on the cells...not sure. I'd stick to tape or shrink wrap...
I've seen some packs that are completely potted, even over the vents (Grin LiGo, for example). I guess if the cell gets to the point where it wants to vent, you have bigger problems anyway. The foam stuff won't hold back a venting cell much anyway. If you could find some foam that doesn't expand much and is pretty hard when cured, it might add some good protection. Forget about ever repairing the pack though. Another approach is to cover the pack with a thin plastic bag, then foam around that so the foam doesn't actually stick to the cells. It would be like a custom foam cushion that could be cut away if needed.
This pack good for 80A max discharge :?: 1mm pure copper wire for the series 6x
The pack:3s 28P 10.8V 81Ah 8AWG wiring no direct heat to the cells on soldering the copper serie/parallels :D
No, I was not thinking of great stuff! LOL. But I read through every thread of this discussion last night and one of the posters mentioned what I am talking about. For example:
https://www.amazon.com/gp/product/B00RZUOCOS/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
or
https://www.amazon.com/3M-1602-R-Electrical-Insulating-Sealer/dp/B001CGVHN0/ref=sr_1_1?ie=UTF8&qid=1518538978&sr=8-1&keywords=3M+1602-R+Electrical+Insulating+Sealer+12-oz+Can+Red
On another note, the folks in Powerwall land ...as well as those who use 18650 packs for EV cars seem quite concerned about fusing individual cells. So on those forums/Youtube etc. there seems to be a lot of use of Bus Bar wire for connecting series cells. An example of it is here, skip to about 12:15 if you do want to watch the whole procedure:
https://www.youtube.com/watch?v=xOVEnbbhbRY&t=118s
So what about this folks? The 20awg busbar wire he is using would only be good for 5 amps to my knowledge, so that doesn't add up for high amp draw situations. But are there any concerns and approaches here for fusing individual cells?
Thanks again
RH
Here is another one, can someone pinpoint any problems of the design of this pack ...and it is specifically designed for an Electric bike. From what I am understanding here is this seems to follow the proper high current pack design ...except for the resistor leads to connect cells?
https://www.youtube.com/watch?v=adUTP92VFqg
If you don't want to watch the whole thing you can see the finished pack around 25:12
I'm not a fan of soldering onto cell ends, especially the negative electrode, but I have to say I would definitely not use the technique shown. He says to get a good soldering iron, and then he shows a 40W unit with a fairly small tip. Then he holds the hot tip onto the negative electrode as an example for about 20 seconds to get a solid solder connection.
I use a 100W soldering iron with a fat tip (for thermal mass, so the tip doesn't cool down as soon as it touches the subject), and I can tin the end of a cell with solder in just a couple seconds, so the heat doesn't reach down deep into the cell.
Nods ...I agree on his soldering technique. But what about the pack design itself? It looks like it is following all the rules here for a design ...except for the possible resistor wires for the fuses/connections. Again, it seems like that is not a concern on this forum as well. On the soldering, from what I have researched ...it depends on how well it is done. The top two (that I can see) followed powerwall/EV pack builders on Youtube both use soldering instead of spot welding. It started from what I can see as a result of the cost of a good spot welder but they seem to have stuck with this technique and are happy with it. Of course, a powerwall does not get the physical abuse that an EV bike probably gets but an EV vehicle could with the condition of roads nowadays! Thanks for taking the time to respond. RH
The main reason the Powerwall guys use individual fuses on the cells (even though it's a fixed non-mobile installation) is because it's popular to build with used cells that are typically $1 each. Sometimes they overheat under normal use...
As pointed out in a previous post, connecting the input/output on the first of all these parallel cells is a big mistake. The first 7 cells of the pack will take most and give most of the power, with each one of the rest of the 10 parallel rows contributing less and less as we move farther from the top.
I know the copper bar will minimize the losses and the difference, but there still going to be a difference and the pack will under-perform.
So exactly how would this design be approved upon? I guess I better go back and read through all of this discussion ...I thought the busbar on those parallel in's and outs were solving this problem.
brumbrum said:
Holy moley batman, my 5 year old daughter could make a pack better than that! :lol:
This type of build will probably cause The Insurance Bureau of Canada to have a exclusionary rider for any type of lithium EV battery stored in/on your premises, attached or unattached garage or out building including a garden shed, this might even extend to eCars and Hybrids.
I'm sure that this will be followed through in many other countries that have experienced residential fires due to Lithium batteries as this has the heaviest cost to loss of life.
Laptops may even be legislated to be powered by a converter with no battery when stored/used in a residence. Laptops and now VAPING fires are a huge contributor to the Li issue, phones, not so much now.
I have been checking on insurance rates for my ebike.
It's coming, the stats are there for the insurance company's to crunch, and as the crooks they are, anything to low ball or prevent a payout they will take advantage of.
Notice the bunk beds?
As best as I can model, that is a near perfect pack; with all the individual cells delivering 2.86A or 2.85A when the pack is delivering 80A.
Its too complex for a url link, so you'd need to paste the following text into File->Import from text, to recreate it:
Code:
$ 1 0.000005 10.200277308269968 50 5 50
w 416 736 464 688 0
w 464 688 512 640 0
r 464 688 400 624 0 0.00004
v 416 736 416 688 0 0 40 4.2 0 0 0.5
r 416 688 416 672 0 0.02
w 416 672 416 624 0
w 512 640 560 592 0
w 560 592 608 544 0
v 512 640 512 592 0 0 40 4.2 0 0 0.5
r 512 592 512 576 0 0.02
w 416 624 464 576 0
w 464 576 512 528 0
w 512 576 512 528 0
r 464 576 400 512 0 0.00004
w 512 528 560 480 0
w 560 480 608 432 0
w 752 288 800 240 0
w 704 336 752 288 0
r 656 384 592 320 0 0.00004
w 704 384 704 336 0
w 656 384 704 336 0
w 608 432 656 384 0
r 704 400 704 384 0 0.02
v 704 448 704 400 0 0 40 4.2 0 0 0.5
w 752 400 800 352 0
w 704 448 752 400 0
w 608 480 608 432 0
r 608 496 608 480 0 0.02
v 608 544 608 496 0 0 40 4.2 0 0 0.5
r 656 496 592 432 0 0.00004
w 656 496 704 448 0
w 608 544 656 496 0
w 944 96 992 48 0
w 896 144 944 96 0
r 848 192 784 128 0 0.00004
w 896 192 896 144 0
w 848 192 896 144 0
w 800 240 848 192 0
r 896 208 896 192 0 0.02
v 896 256 896 208 0 0 40 4.2 0 0 0.5
w 944 208 992 160 0
w 896 256 944 208 0
w 800 288 800 240 0
r 800 304 800 288 0 0.02
v 800 352 800 304 0 0 40 4.2 0 0 0.5
r 848 304 784 240 0 0.00004
w 848 304 896 256 0
w 800 352 848 304 0
w 992 96 992 48 0
r 992 112 992 96 0 0.02
v 992 160 992 112 0 0 40 4.2 0 0 0.5
r 560 592 496 528 0 0.00004
r 752 400 688 336 0 0.00004
r 944 208 880 144 0 0.00004
r 560 480 496 416 0 0.00004
r 752 288 688 224 0 0.00004
r 944 96 880 32 0 0.00004
r 880 32 816 -32 0 0.00004
r 688 224 624 160 0 0.00004
r 496 416 432 352 0 0.00004
r 880 144 816 80 0 0.00004
r 688 336 624 272 0 0.00004
r 496 528 432 464 0 0.00004
v 928 96 928 48 0 0 40 4.2 0 0 0.5
r 928 48 928 32 0 0.02
w 928 32 928 -16 0
w 736 288 784 240 0
w 784 240 832 192 0
r 784 240 720 176 0 0.00004
v 736 288 736 240 0 0 40 4.2 0 0 0.5
r 736 240 736 224 0 0.02
w 736 224 736 176 0
w 832 192 880 144 0
w 880 144 928 96 0
v 832 192 832 144 0 0 40 4.2 0 0 0.5
r 832 144 832 128 0 0.02
w 736 176 784 128 0
w 784 128 832 80 0
w 832 128 832 80 0
r 784 128 720 64 0 0.00004
w 832 80 880 32 0
w 880 32 928 -16 0
w 544 480 592 432 0
w 592 432 640 384 0
r 592 432 528 368 0 0.00004
v 544 480 544 432 0 0 40 4.2 0 0 0.5
r 544 432 544 416 0 0.02
w 544 416 544 368 0
w 640 384 688 336 0
w 688 336 736 288 0
v 640 384 640 336 0 0 40 4.2 0 0 0.5
r 640 336 640 320 0 0.02
w 544 368 592 320 0
w 592 320 640 272 0
w 640 320 640 272 0
r 592 320 528 256 0 0.00004
w 640 272 688 224 0
w 688 224 736 176 0
w 496 416 544 368 0
w 448 464 496 416 0
r 400 512 336 448 0 0.00004
w 448 512 448 464 0
w 400 512 448 464 0
w 352 560 400 512 0
r 448 528 448 512 0 0.02
v 448 576 448 528 0 0 40 4.2 0 0 0.5
w 496 528 544 480 0
w 448 576 496 528 0
w 352 608 352 560 0
r 352 624 352 608 0 0.02
v 352 672 352 624 0 0 40 4.2 0 0 0.5
r 400 624 336 560 0 0.00004
w 400 624 448 576 0
w 352 672 400 624 0
r 816 -32 752 -96 0 0.00004
r 624 160 560 96 0 0.00004
r 432 352 368 288 0 0.00004
r 816 80 752 16 0 0.00004
r 624 272 560 208 0 0.00004
r 432 464 368 400 0 0.00004
v 864 32 864 -16 0 0 40 4.2 0 0 0.5
r 864 -16 864 -32 0 0.02
w 864 -32 864 -80 0
w 672 224 720 176 0
w 720 176 768 128 0
r 720 176 656 112 0 0.00004
v 672 224 672 176 0 0 40 4.2 0 0 0.5
r 672 176 672 160 0 0.02
w 672 160 672 112 0
w 768 128 816 80 0
w 816 80 864 32 0
v 768 128 768 80 0 0 40 4.2 0 0 0.5
r 768 80 768 64 0 0.02
w 672 112 720 64 0
w 720 64 768 16 0
w 768 64 768 16 0
r 720 64 656 0 0 0.00004
w 768 16 816 -32 0
w 816 -32 864 -80 0
w 480 416 528 368 0
w 528 368 576 320 0
r 528 368 464 304 0 0.00004
v 480 416 480 368 0 0 40 4.2 0 0 0.5
r 480 368 480 352 0 0.02
w 480 352 480 304 0
w 576 320 624 272 0
w 624 272 672 224 0
v 576 320 576 272 0 0 40 4.2 0 0 0.5
r 576 272 576 256 0 0.02
w 480 304 528 256 0
w 528 256 576 208 0
w 576 256 576 208 0
r 528 256 464 192 0 0.00004
w 576 208 624 160 0
w 624 160 672 112 0
w 432 352 480 304 0
w 384 400 432 352 0
r 336 448 272 384 0 0.00004
w 384 448 384 400 0
w 336 448 384 400 0
w 288 496 336 448 0
r 384 464 384 448 0 0.02
v 384 512 384 464 0 0 40 4.2 0 0 0.5
w 432 464 480 416 0
w 384 512 432 464 0
w 288 544 288 496 0
r 288 560 288 544 0 0.02
v 288 608 288 560 0 0 40 4.2 0 0 0.5
r 336 560 272 496 0 0.00004
w 336 560 384 512 0
w 288 608 336 560 0
r 752 -96 688 -160 0 0.00004
r 560 96 496 32 0 0.00004
r 368 288 304 224 0 0.00004
r 688 -48 624 -112 0 0.00004
r 496 144 432 80 0 0.00004
r 304 336 240 272 0 0.00004
v 800 -32 800 -80 0 0 40 4.2 0 0 0.5
r 800 -80 800 -96 0 0.02
w 800 -96 800 -144 0
w 608 160 656 112 0
w 656 112 704 64 0
r 592 48 528 -16 0 0.00004
v 608 160 608 112 0 0 40 4.2 0 0 0.5
r 608 112 608 96 0 0.02
w 608 96 608 48 0
w 704 64 752 16 0
w 752 16 800 -32 0
v 704 64 704 16 0 0 40 4.2 0 0 0.5
r 704 16 704 0 0 0.02
w 608 48 656 0 0
w 656 0 704 -48 0
w 704 0 704 -48 0
r 656 0 592 -64 0 0.00004
w 704 -48 752 -96 0
w 752 -96 800 -144 0
w 416 352 464 304 0
w 464 304 512 256 0
r 400 240 336 176 0 0.00004
v 416 352 416 304 0 0 40 4.2 0 0 0.5
r 416 304 416 288 0 0.02
w 416 288 416 240 0
w 512 256 560 208 0
w 560 208 608 160 0
v 512 256 512 208 0 0 40 4.2 0 0 0.5
r 512 208 512 192 0 0.02
w 416 240 464 192 0
w 464 192 512 144 0
w 512 192 512 144 0
r 464 192 400 128 0 0.00004
w 512 144 560 96 0
w 560 96 608 48 0
w 368 288 416 240 0
w 320 336 368 288 0
r 272 384 208 320 0 0.00004
w 320 384 320 336 0
w 272 384 320 336 0
w 224 432 272 384 0
r 320 400 320 384 0 0.02
v 320 448 320 400 0 0 40 4.2 0 0 0.5
w 368 400 416 352 0
w 320 448 368 400 0
w 224 480 224 432 0
r 224 496 224 480 0 0.02
v 224 544 224 496 0 0 40 4.2 0 0 0.5
r 208 432 144 368 0 0.00004
w 272 496 320 448 0
w 224 544 272 496 0
r 688 -160 624 -224 0 0.00004
r 496 32 432 -32 0 0.00004
r 304 224 240 160 0 0.00004
r 736 -144 736 -160 0 0.02
w 736 -160 736 -208 0
w 544 96 592 48 0
w 592 48 640 0 0
r 544 48 544 32 0 0.02
w 544 32 544 -16 0
w 640 0 688 -48 0
w 688 -48 736 -96 0
r 640 -48 640 -64 0 0.02
w 544 -16 592 -64 0
w 592 -64 640 -112 0
w 640 -64 640 -112 0
r 592 -64 528 -128 0 0.00004
w 640 -112 688 -160 0
w 688 -160 736 -208 0
w 352 288 400 240 0
w 400 240 448 192 0
r 352 240 352 224 0 0.02
w 352 224 352 176 0
w 448 192 496 144 0
w 496 144 544 96 0
r 448 144 448 128 0 0.02
w 352 176 400 128 0
w 400 128 448 80 0
w 448 128 448 80 0
r 400 128 336 64 0 0.00004
w 448 80 496 32 0
w 496 32 544 -16 0
w 304 224 352 176 0
w 256 272 304 224 0
r 208 320 144 256 0 0.00004
w 256 320 256 272 0
w 208 320 256 272 0
w 160 368 208 320 0
r 256 336 256 320 0 0.02
w 304 336 352 288 0
w 256 384 304 336 0
w 160 416 160 368 0
r 160 432 160 416 0 0.02
w 208 432 256 384 0
w 160 480 208 432 0
r 624 -224 560 -288 0 0.00004
r 432 -32 368 -96 0 0.00004
r 240 160 176 96 0 0.00004
r 624 -112 560 -176 0 0.00004
r 432 80 368 16 0 0.00004
r 240 272 176 208 0 0.00004
r 672 -208 672 -224 0 0.02
w 672 -224 672 -272 0
w 480 32 528 -16 0
w 528 -16 576 -64 0
r 528 -16 464 -80 0 0.00004
r 480 -16 480 -32 0 0.02
w 480 -32 480 -80 0
w 576 -64 624 -112 0
w 624 -112 672 -160 0
r 576 -112 576 -128 0 0.02
w 480 -80 528 -128 0
w 528 -128 576 -176 0
w 576 -128 576 -176 0
r 528 -128 464 -192 0 0.00004
w 576 -176 624 -224 0
w 624 -224 672 -272 0
w 288 224 336 176 0
w 336 176 384 128 0
r 336 176 272 112 0 0.00004
r 288 176 288 160 0 0.02
w 288 160 288 112 0
w 384 128 432 80 0
w 432 80 480 32 0
r 384 80 384 64 0 0.02
w 288 112 336 64 0
w 336 64 384 16 0
w 384 64 384 16 0
r 336 64 272 0 0 0.00004
w 384 16 432 -32 0
w 432 -32 480 -80 0
w 240 160 288 112 0
w 192 208 240 160 0
r 144 256 80 192 0 0.00004
w 192 256 192 208 0
w 144 256 192 208 0
w 96 304 144 256 0
r 192 272 192 256 0 0.02
w 240 272 288 224 0
w 192 320 240 272 0
w 96 352 96 304 0
r 96 368 96 352 0 0.02
r 144 368 80 304 0 0.00004
w 144 368 192 320 0
w 96 416 144 368 0
r 560 -288 496 -352 0 0.00004
r 368 -96 304 -160 0 0.00004
r 176 96 112 32 0 0.00004
r 560 -176 496 -240 0 0.00004
r 368 16 304 -48 0 0.00004
r 176 208 112 144 0 0.00004
r 608 -272 608 -288 0 0.02
w 608 -288 608 -336 0
w 416 -32 464 -80 0
w 464 -80 512 -128 0
r 464 -80 400 -144 0 0.00004
r 416 -80 416 -96 0 0.02
w 416 -96 416 -144 0
w 512 -128 560 -176 0
w 560 -176 608 -224 0
r 512 -176 512 -192 0 0.02
w 416 -144 464 -192 0
w 464 -192 512 -240 0
w 512 -192 512 -240 0
r 464 -192 400 -256 0 0.00004
w 512 -240 560 -288 0
w 560 -288 608 -336 0
w 224 160 272 112 0
w 272 112 320 64 0
r 272 112 208 48 0 0.00004
r 224 112 224 96 0 0.02
w 224 96 224 48 0
w 320 64 368 16 0
w 368 16 416 -32 0
r 320 16 320 0 0 0.02
w 224 48 272 0 0
w 272 0 320 -48 0
w 320 0 320 -48 0
r 272 0 208 -64 0 0.00004
w 320 -48 368 -96 0
w 368 -96 416 -144 0
w 176 96 224 48 0
w 128 144 176 96 0
r 80 192 16 128 0 0.00004
w 128 192 128 144 0
w 80 192 128 144 0
w 32 240 80 192 0
r 128 208 128 192 0 0.02
w 176 208 224 160 0
w 128 256 176 208 0
w 32 288 32 240 0
r 32 304 32 288 0 0.02
r 80 304 16 240 0 0.00004
w 80 304 128 256 0
w 32 352 80 304 0
r 496 -240 432 -304 0 0.00004
r 304 -48 240 -112 0 0.00004
r 112 144 48 80 0 0.00004
r 544 -336 544 -352 0 0.02
w 544 -352 544 -400 0
w 352 -96 400 -144 0
w 400 -144 448 -192 0
r 400 -144 336 -208 0 0.00004
r 352 -144 352 -160 0 0.02
w 352 -160 352 -208 0
w 448 -192 496 -240 0
w 496 -240 544 -288 0
r 448 -240 448 -256 0 0.02
w 352 -208 400 -256 0
w 400 -256 448 -304 0
w 448 -256 448 -304 0
w 448 -304 496 -352 0
w 496 -352 544 -400 0
w 160 96 208 48 0
w 208 48 256 0 0
r 208 48 144 -16 0 0.00004
r 160 48 160 32 0 0.02
w 160 32 160 -16 0
w 256 0 304 -48 0
w 304 -48 352 -96 0
r 256 -48 256 -64 0 0.02
w 160 -16 208 -64 0
w 208 -64 256 -112 0
w 256 -64 256 -112 0
w 256 -112 304 -160 0
w 304 -160 352 -208 0
w 112 32 160 -16 0
w 64 80 112 32 0
w 64 128 64 80 0
w 16 128 64 80 0
w -32 176 16 128 0
r 64 144 64 128 0 0.02
w 112 144 160 96 0
w 64 192 112 144 0
w -32 224 -32 176 0
r -32 240 -32 224 0 0.02
r 16 240 -48 176 0 0.00004
w 16 240 64 192 0
w -32 288 16 240 0
r 432 -416 368 -480 0 0.00004
r 240 -224 176 -288 0 0.00004
r 48 -32 -16 -96 0 0.00004
r 432 -304 368 -368 0 0.00004
r 240 -112 176 -176 0 0.00004
r 48 80 -16 16 0 0.00004
v 480 -352 480 -400 0 0 40 4.2 0 0 0.5
r 480 -400 480 -416 0 0.02
w 480 -416 480 -464 0
w 288 -160 336 -208 0
w 336 -208 384 -256 0
r 336 -208 272 -272 0 0.00004
v 288 -160 288 -208 0 0 40 4.2 0 0 0.5
r 288 -208 288 -224 0 0.02
w 288 -224 288 -272 0
w 384 -256 432 -304 0
w 432 -304 480 -352 0
v 384 -256 384 -304 0 0 40 4.2 0 0 0.5
r 384 -304 384 -320 0 0.02
w 288 -272 336 -320 0
w 336 -320 384 -368 0
w 384 -320 384 -368 0
r 336 -320 272 -384 0 0.00004
w 384 -368 432 -416 0
w 432 -416 480 -464 0
w 96 32 144 -16 0
w 144 -16 192 -64 0
r 144 -16 80 -80 0 0.00004
v 96 32 96 -16 0 0 40 4.2 0 0 0.5
r 96 -16 96 -32 0 0.02
w 96 -32 96 -80 0
w 192 -64 240 -112 0
w 240 -112 288 -160 0
v 192 -64 192 -112 0 0 40 4.2 0 0 0.5
r 192 -112 192 -128 0 0.02
w 96 -80 144 -128 0
w 144 -128 192 -176 0
w 192 -128 192 -176 0
r 144 -128 80 -192 0 0.00004
w 192 -176 240 -224 0
w 240 -224 288 -272 0
w 48 -32 96 -80 0
w 0 16 48 -32 0
r -48 64 -112 0 0 0.00004
w 0 64 0 16 0
w -48 64 0 16 0
w -96 112 -48 64 0
r 0 80 0 64 0 0.02
v 0 128 0 80 0 0 40 4.2 0 0 0.5
w 48 80 96 32 0
w 0 128 48 80 0
w -96 160 -96 112 0
r -96 176 -96 160 0 0.02
v -96 224 -96 176 0 0 40 4.2 0 0 0.5
r -48 176 -112 112 0 0.00004
w -48 176 0 128 0
w -96 224 -48 176 0
r 368 -480 304 -544 0 0.00004
r 176 -288 112 -352 0 0.00004
r -16 -96 -80 -160 0 0.00004
r 368 -368 304 -432 0 0.00004
r 176 -176 112 -240 0 0.00004
r -16 16 -80 -48 0 0.00004
v 416 -416 416 -464 0 0 40 4.2 0 0 0.5
r 416 -464 416 -480 0 0.02
w 416 -480 416 -528 0
w 224 -224 272 -272 0
w 272 -272 320 -320 0
r 272 -272 208 -336 0 0.00004
v 224 -224 224 -272 0 0 40 4.2 0 0 0.5
r 224 -272 224 -288 0 0.02
w 224 -288 224 -336 0
w 320 -320 368 -368 0
w 368 -368 416 -416 0
v 320 -320 320 -368 0 0 40 4.2 0 0 0.5
r 320 -368 320 -384 0 0.02
w 224 -336 272 -384 0
w 272 -384 320 -432 0
w 320 -384 320 -432 0
r 272 -384 208 -448 0 0.00004
w 320 -432 368 -480 0
w 368 -480 416 -528 0
w 32 -32 80 -80 0
w 80 -80 128 -128 0
r 80 -80 16 -144 0 0.00004
v 32 -32 32 -80 0 0 40 4.2 0 0 0.5
r 32 -80 32 -96 0 0.02
w 32 -96 32 -144 0
w 128 -128 176 -176 0
w 176 -176 224 -224 0
v 128 -128 128 -176 0 0 40 4.2 0 0 0.5
r 128 -176 128 -192 0 0.02
w 32 -144 80 -192 0
w 80 -192 128 -240 0
w 128 -192 128 -240 0
r 80 -192 16 -256 0 0.00004
w 128 -240 176 -288 0
w 176 -288 224 -336 0
w -16 -96 32 -144 0
w -64 -48 -16 -96 0
r -112 0 -176 -64 0 0.00004
w -64 0 -64 -48 0
w -112 0 -64 -48 0
w -160 48 -112 0 0
r -64 16 -64 0 0 0.02
v -64 64 -64 16 0 0 40 4.2 0 0 0.5
w -16 16 32 -32 0
w -64 64 -16 16 0
w -160 96 -160 48 0
r -160 112 -160 96 0 0.02
v -160 160 -160 112 0 0 40 4.2 0 0 0.5
r -112 112 -176 48 0 0.00004
w -112 112 -64 64 0
w -160 160 -112 112 0
r 304 -544 240 -608 0 0.00004
r 112 -352 48 -416 0 0.00004
r -80 -160 -144 -224 0 0.00004
r 304 -432 240 -496 0 0.00004
r 112 -240 48 -304 0 0.00004
r -80 -48 -144 -112 0 0.00004
v 352 -480 352 -528 0 0 40 4.2 0 0 0.5
r 352 -528 352 -544 0 0.02
w 352 -544 352 -592 0
w 160 -288 208 -336 0
w 208 -336 256 -384 0
r 208 -336 144 -400 0 0.00004
v 160 -288 160 -336 0 0 40 4.2 0 0 0.5
r 160 -336 160 -352 0 0.02
w 160 -352 160 -400 0
w 256 -384 304 -432 0
w 304 -432 352 -480 0
v 256 -384 256 -432 0 0 40 4.2 0 0 0.5
r 256 -432 256 -448 0 0.02
w 160 -400 208 -448 0
w 208 -448 256 -496 0
w 256 -448 256 -496 0
r 208 -448 144 -512 0 0.00004
w 256 -496 304 -544 0
w 304 -544 352 -592 0
w -32 -96 16 -144 0
w 16 -144 64 -192 0
r 16 -144 -48 -208 0 0.00004
v -32 -96 -32 -144 0 0 40 4.2 0 0 0.5
r -32 -144 -32 -160 0 0.02
w -32 -160 -32 -208 0
w 64 -192 112 -240 0
w 112 -240 160 -288 0
v 64 -192 64 -240 0 0 40 4.2 0 0 0.5
r 64 -240 64 -256 0 0.02
w -32 -208 16 -256 0
w 16 -256 64 -304 0
w 64 -256 64 -304 0
r 16 -256 -48 -320 0 0.00004
w 64 -304 112 -352 0
w 112 -352 160 -400 0
w -80 -160 -32 -208 0
w -128 -112 -80 -160 0
r -176 -64 -240 -128 0 0.00004
w -128 -64 -128 -112 0
w -176 -64 -128 -112 0
w -224 -16 -176 -64 0
r -128 -48 -128 -64 0 0.02
v -128 0 -128 -48 0 0 40 4.2 0 0 0.5
w -80 -48 -32 -96 0
w -128 0 -80 -48 0
w -224 32 -224 -16 0
r -224 48 -224 32 0 0.02
v -224 96 -224 48 0 0 40 4.2 0 0 0.5
r -176 48 -240 -16 0 0.00004
w -176 48 -128 0 0
w -224 96 -176 48 0
r -144 -224 -208 -288 0 0.00004
v 288 -544 288 -592 0 0 40 4.2 0 0 0.5
r 288 -592 288 -608 0 0.02
w 288 -608 288 -656 0
w 96 -352 144 -400 0
w 144 -400 192 -448 0
v 96 -352 96 -400 0 0 40 4.2 0 0 0.5
r 96 -400 96 -416 0 0.02
w 96 -416 96 -464 0
w 192 -448 240 -496 0
w 240 -496 288 -544 0
v 192 -448 192 -496 0 0 40 4.2 0 0 0.5
r 192 -496 192 -512 0 0.02
w 96 -464 144 -512 0
w 144 -512 192 -560 0
w 192 -512 192 -560 0
r 144 -512 80 -576 0 0.00004
w 192 -560 240 -608 0
w 240 -608 288 -656 0
w -96 -160 -48 -208 0
w -48 -208 0 -256 0
v -96 -160 -96 -208 0 0 40 4.2 0 0 0.5
r -96 -208 -96 -224 0 0.02
w -96 -224 -96 -272 0
w 0 -256 48 -304 0
w 48 -304 96 -352 0
v 0 -256 0 -304 0 0 40 4.2 0 0 0.5
r 0 -304 0 -320 0 0.02
w -96 -272 -48 -320 0
w -48 -320 0 -368 0
w 0 -320 0 -368 0
w 0 -368 48 -416 0
w 48 -416 96 -464 0
w -144 -224 -96 -272 0
w -192 -176 -144 -224 0
w -192 -128 -192 -176 0
w -240 -128 -192 -176 0
w -288 -80 -240 -128 0
r -192 -112 -192 -128 0 0.02
v -192 -64 -192 -112 0 0 40 4.2 0 0 0.5
w -144 -112 -96 -160 0
w -192 -64 -144 -112 0
w -288 -32 -288 -80 0
r -288 -16 -288 -32 0 0.02
v -288 32 -288 -16 0 0 40 4.2 0 0 0.5
w -240 -16 -192 -64 0
w -288 32 -240 -16 0
w 464 688 512 736 0
w 656 496 704 544 0
w 752 400 800 448 0
w 944 208 992 256 0
r 512 736 608 640 0 0.000052
r 608 640 704 544 0 0.000052
r 800 448 896 352 0 0.000052
r 896 352 992 256 0 0.000052
r -304 -192 -208 -288 0 0.000052
r -208 -288 -112 -384 0 0.000052
r -16 -480 80 -576 0 0.000052
r 80 -576 176 -672 0 0.000052
w 608 640 656 688 0
w 896 352 944 400 0
r 656 688 800 544 0 0.00001
r 800 544 944 400 0 0.00001
w 800 544 944 672 0
w 944 672 944 752 0
w 944 752 -272 752 0
w 80 -576 32 -624 0
w -208 -288 -256 -336 0
r -112 -480 32 -624 0 0.00001
r -256 -336 -112 -480 0 0.00001
w -112 -480 -192 -560 0
w -192 -560 -512 -224 0
w -512 -224 -512 528 0
r -512 528 -272 752 0 0.15528
v -32 240 -32 288 0 0 40 4.2 0 0 0.5
v 64 144 64 192 0 0 40 4.2 0 0 0.5
v 160 48 160 96 0 0 40 4.2 0 0 0.5
v 256 -48 256 0 0 0 40 4.2 0 0 0.5
v 352 -144 352 -96 0 0 40 4.2 0 0 0.5
v 448 -240 448 -192 0 0 40 4.2 0 0 0.5
v 32 304 32 352 0 0 40 4.2 0 0 0.5
v 224 112 224 160 0 0 40 4.2 0 0 0.5
v 320 16 320 64 0 0 40 4.2 0 0 0.5
v 416 -80 416 -32 0 0 40 4.2 0 0 0.5
v 512 -176 512 -128 0 0 40 4.2 0 0 0.5
v 608 -272 608 -224 0 0 40 4.2 0 0 0.5
v 544 -336 544 -288 0 0 40 4.2 0 0 0.5
v 96 368 96 416 0 0 40 4.2 0 0 0.5
v 192 272 192 320 0 0 40 4.2 0 0 0.5
v 288 176 288 224 0 0 40 4.2 0 0 0.5
v 384 80 384 128 0 0 40 4.2 0 0 0.5
v 480 -16 480 32 0 0 40 4.2 0 0 0.5
v 576 -112 576 -64 0 0 40 4.2 0 0 0.5
v 672 -208 672 -160 0 0 40 4.2 0 0 0.5
v 128 208 128 256 0 0 40 4.2 0 0 0.5
v 160 432 160 480 0 0 40 4.2 0 0 0.5
v 256 336 256 384 0 0 40 4.2 0 0 0.5
v 352 240 352 288 0 0 40 4.2 0 0 0.5
v 448 144 448 192 0 0 40 4.2 0 0 0.5
v 544 48 544 96 0 0 40 4.2 0 0 0.5
v 640 -48 640 0 0 0 40 4.2 0 0 0.5
v 736 -144 736 -96 0 0 40 4.2 0 0 0.5
r 896 352 848 304 0 0.00004
w -240 -128 -304 -192 0
w -48 -320 -112 -384 0
w 48 -416 -16 -480 0
w 240 -608 176 -672 0
r 608 640 560 592 0 0.00004
This is nice Buk! Basically, you are using copper to minimize resistance and trying to keep equal distances from root to each parallel cell. I say it's perfect enough for pragmatic applications.
After the last complicated 16p pack I've made, I though I should try a much easier and possibly better way of connecting my cells. I have ordered a 0.9mm thick C101 copper sheet to cut to pieces that cover all the parallel ends. Then spot weld 2cm long 7x0.15mm nickel strips on the cell ends. Cut through the copper right where the nickel strip is, to let the nickel strip go through the cut. Then fold the remaining nickel strip (Approximately 1cm long) on top of the copper that lies on top of the parallel cells and spot weld again! This should practically give me no resistance (ok, it's just minimal) from the wire to each cell because the current will go through the whole copper until it reaches a very small portion of nickel and then go though the cell.
Once I receive the copper sheet I've ordered and try it, I'll post pictures. :D
All the props go to Joachim, he built it. All I did was try to model it :)
