mjayt said:So I have my wiring harness made for my bac2000 and every thing test out with a continuity test light. When I first connected the harness to the controller and my computer, it would not connect. I then tested to makes sure that every thing was making contact. As said the continuity test showed juice flowing where it should when it should, but it would just time out when connectig to the BAC software. Then it started crashing the BAC software Giving "windows has found a problem with this software and needs to shut it down" error. I was running the 1.5.3 version then, so I uninstalled it and reinstalled the 1.5.4 version and it is still crashing when I press connect. it crashes regardless if the controller ttl connecter is attached or not.
Anyone else having this issue with windows 8.1 and the BAC Door 1.5.4 program? if so have you been able to fix it? what did you do to fix it?
Still trouble shooting the issue, but any help would be appreciated.
I also confirmed the ttl cable is working fine by upgrading to prelim10 on my CA3 after BAC Door started crashing.
.3 or .4 are both stable, try to Run as administrator in your Win8 OS?
