xXSaneXx
🔋 Established
First off, hi, I'm new here an new to the ebike diy part. I own a XP Lite and love it, I'm also building a 20inch bmx ebike.
I bought a controller with 17a setup for a 24v, 36v an 48v depending how I set it up. I'm planning on going 48v10ah battery with a 30amp bms. Is that to much on a 17a controller? The rear hub I'm using is a 300w xp lite hub with a 719 wat peak. Now upon research on here I sen someone say you multiply the battery voltage times the amp controller an that will tell you the combined wattage the motor will push out. Now, I don't plan on making it go super fast but I don't wanna burn it up either.
Would I be ok using a 48v10ah battery on that controller? Like I said I'm not planing on going super fast, 20mph is fine with a rigid frame lol, granted I will be upgrading to a suntour front fork and a suspension seat post after it's rideable.
Thank you for your help
I'm using a 20inch steel mongoose bmx, it's light so it should be fun
