Whiplash
- Joined
- May 10, 2010
- Messages
- 2,906
OK I have been doing some research on this, and I have decided to build my own gearboxes for now. I have a design worked up and I played with some ratios and with a 3 stage gearbox, I can keep the form factor really small while still having all gears with decent tooth counts for strength. I plan on simply welding the gears onto the shafts and having the shafts on high speed quality bearings. I am planning on three stages with a 16T drive and a 48T driven on each stage. This will give me a total reduction of 27:1 which is only slightly lower gearing than my current box of 25:1 so I am really excited about this! PLUS the motor will be more or less part of the box and require no adjustment for chain tightness, ETC! this is the way to do it for sure! I just hope they are fairly quiet, but if they are a bit noisy, I think I could run some lapping compound through the box just to mate all the surfaces and hopefully quiet it up, plus the fact that it's enclosed and in oil will really help as well. Oh and the box is only going to be approx. 3" deep by no more than 6-7"now and have no exposed sprockets except the freewheel for the output shaft, and the motor itself! I am doing a side job this weekend that will pay for the ears, so I can get started building, it will take a bit to get it figured out I am sure, but this is a much better option and with nice sized gears at 3/8" wide, I think it will be plenty sturdy as well! The 27:1 ratio combined with the new rear 11/34 cluster I am going to get (VS my current 11/32) should give me WAAY better climbing power than even before! I wanted to slow it down since it was still a little fast going up big stuff! Lookout goat trails here I come!
If anyone is interested. initial figuring for production quantities puts the box sale price (WITH 2,500ish watt MOTOR) at around $300ish as long as I don't run into any problems, so it should be very reasonable for a bolt it on and go setup! Even if it goes up a bit... And believe me, that is MORE than enough power when going through the gears! I had 1200-1500 watts before and it would climb ANYTHING!! Even straight up big rocks!
