recumpence
1 GW
Hey Dave,
I gotta say, this is the perfect application for your drive.
Matt
Matt
Joe T. said:Can the Castle Creations HV80 be used without the Cycle Analyst? I understand it is nice to have but I don't know if you need it to make it work.
It looks so small compared to my no-name controller on my bike.
You mean for the bike chaining? I'd use a 36t. It's not too large but still big enough to give good top speed. The 36t cassette will give lots of gear range with a ton of slow speed torque. The 11t cog may wear fast and if you do need more climbing torque, a 42t granny cog should climb a tree.aCeMadMod said:hi dave i need some help if was to use your 40/1 gearbox with only 1 chian ring what size would be Good with a 11/36 rear
it for my 2.0 Cyclone giant glory downhill Max mods % pics
https://endless-sphere.com/forums/viewtopic.php?f=28&t=83009
i can't just test chianrings, i have 1 shot deal cutting the motor plate, any help would be nice thank you
izeman said:You would need to give your desired speed and voltage to find the correct chain ring.
i am do what i been told too , lipo 12s 49 volt 16 ha . flat ground speed lke 40 to 45km, 20% to 25% climb speed 20 km, and %30 15 km or more speed
will that help you pick to front chainring ? gearbox 16 is teeth rear cass 11/36
thak you dave 8)
loook like you need make the watercooling , told you about very long time ago, i had a feeling you can crook your motor, without C.a 3.0 to stop temp killing it .
Alex07 said:loook like you need make the watercooling , told you about very long time ago, i had a feeling you can crook your motor, without C.a 3.0 to stop temp killing it .
its not suprise the astro 3220 over heat at only 5kw peak, i don't know how some people think this is a 10kw motor ??? even if it can do that for a few seconds. The continuous rating of this motor is only 3750w , to stop it overheating you will have to reduce the current as its a sealed motor . what is the efficiency of this motor at 5kw input power? its high at 93% at low 1280w power but what is it at 5kw?
Alex07 said:The point being is that this is a normal sealed 3220 and it cannot handle 5kw for 2 laps without overheating as the thermal mass is so low .
Their is no point comparing to exotically cooled motors with air or water, heck any junk motor you cool with liquid nitrogen will handle 3 or 4 times its normal rating ! But these are costly, heavy , inefficient and impractical solutions for most people on bicycle , dirt dust/water don't mix with motors.
And this is a real world example that the motor overheated in 2 laps, so it makes sense that the manufacturers rating is so low continuous 3750w, other readers also new it would overheat so it gives people some real world perspective of what to expect ...
Ok fine with exotic cooling or in a lab experiment in can handle peaks of 14kw for a drag race for 10 seconds, doesn't mean it can handle 2 laps on a track at 5kw which is more like real road use of a 20-30 min hard ride that you would expect it to not overheat.
