Tangent/Zerode Lost Sierra race build:
-5kW (95A @ 52V, Astro 3220+TalonHV 120)
-8spd Shimano Alfine IGH
-14s LiPo, 20Ah
-188ft-lbs wheel torque @15mph; 62ft-lbs wheel torque @ 45mph (I've seen 45mph, it's gearing limited)
-51lbs
-Cane Creek Double Barrel rear
-Marzocchi 888 Ti forks
-Chris King hubs, Maxxis DHF rubber, carbon Race Face bars
Quick math calculates the output of the drive at 81ft-lbs (20:1 internal, 95A @ 8.2in-oz/amp). The primary chain is a 1:1 ratio between the motor and IGH so the hub doesn't see too much more torque than a 200lb rider can generate. (edit: the motor's 80ft-lbs goes into a 16t sprocket, the rider's 100ft-lbs goes into a 32t-ish sprocket). There is an additional secondary reduction between the wheel and hub, further reducing the stress it sees (26t IGH output, 32t at the wheel). I'm using the back half of a standard cassette for the 32t cog, the other two cogs aren't used but add some lateral strength and prevent one narrow cog from digging into the freewheel. The trigger shifter is a bit awkward on the throttle side, a left hand twist shifter is on the way.
It took 6 tries to get the mounts and chain tension to play nicely. I'm using a tension wheel on the back side and the brace between the motor and IGH is solid one piece. Tension adjustment and mounting is actually pretty easy.
What's it ride like? Soooo smooth and fast, it just keeps rolling. The rear end is unflappable, as if there were no tire at all. No squirming under power and no squat, it just goes over everything and I don't feel it, all I think about is the front.
Where would one ride such a beast? At the front of the Open Throttle class of course:
Come out and bring your bike! Chris at Eco Bike Adventures is a super nice guy and hosting the first open class ebike race. 15 miles of racing through beautiful Northern Cali? Yes. Please. Bring your bike, bring some food and beers, have a good time. See you there.
https://endless-sphere.com/forums/viewtopic.php?f=25&t=82001
http://www.ecobikeadv.com/
-dave
