Quick update, build still in progress.
Zerode G2 with 7kW of awesome. This is running a 3220 at 150A phase current, 20:1 Tangent gearbox, BAC2000 speed controller with 12S 32Ah LiPo (for now) and is good for 11.5k motor RPM. The motor freewheel is a 16t while the Shimano Alfine 8 IGH uses 16t receiving cog and I've also matched the cog at the rear wheel to the IGH's output cog (26t->26t) so the only reductions are the 20:1 Tangent and the ratios inside the IGH. The Zerode normally uses a 21t at the rear wheel but I've increased that to reduce the top speed and stress on the IGH.
There is a small amount of flex in the mount because I'm not running the chain to the BB as designed. I'll rotate the downtube brace clockwise to put more metal above the freewheel and more inline with where the chain is pulling. The IGH is handling the torque fine- some quick math:
3220 4turn @ 150A-> 6.4ft-lbs
6.4x20= 128ft-lbs on a 16t sprocket
200lb person standing on the cranks= 115ft-lbs (200lbs x 0.55ft) on a 32t sprocket
So, even at 7kW the IGH and bicycle components handle the forces fine. The motor will make at best double the forces an average person would but in a smooth and constant manner. The fun is the drive outputs 500RPM with this power. From Sheldon Brown:
First gear spins the wheel up to (500x0.52=260RPM) 20mph and eighth gear is 61mph (calculated, I need to true the wheels). Controllable wheelies, enough torque for crawling, top speed to keep up with any traffic, this isn't an ebike anymore. The downside of this setup is the battery requirements aren't as convenient since this monster wants about 120A of battery current.
I'll be redoing the mounts in the next couple days and going for a trail ride. Crash cam to follow...
-dave
*edited to clarify torque ratios
