I will put a hub motor because I will take the parts from my old ebike to this new frame. But if this frame works good I think I will build frame with mid drive. It would be better for offroad.Good start. Make it a mid drive. Use a modern tapered headset. Make it accept big wheels/tires like fat bikes use.
Those are Turbinators. I bought those couple years ago but I couldn't find them anymore for sale. Those are wider than hubsinks and they are little curved.Cooling fins around the hub circumference is... Wonderful design. Where is that unit sourced?
Looks great! Also with the angle of the photo, it looks like the two legs of the wooden table behind it are part of the frame. Had to look twice and wonder why your frame would have been skillfully-welded metal, as well as haphazard wood scrap
Yes the wood table wasn't best background for the frame, it blends pretty good to itLooks great! Also with the angle of the photo, it looks like the two legs of the wooden table behind it are part of the frame. Had to look twice and wonder why your frame would have been skillfully-welded metal, as well as haphazard wood scrap
swingarm is 3mm thick and the smaller tubing on the frame is 1.5mmIll be following your build. Whats the thickness of the tube you are using?
Yes I work outside. In winter when its cold I can't work too long because my fingers freeze. and lately its been around -20°C to -30°C so the project hasn't progressed very fast.Your work is outside in the snow?
I assume you mean the threads only cut a small amount into the tube, so you should have used a smaller tube. What did you use and what would you use next time?I made a little mistake. The bottom bracket tube was little too big, so the threads isn't really good. The bottom bracket does thread good on there, but I don't know if it will hold. I will put some loctite and see if it will hold in place. But if not I might weld it.
View attachment 346185View attachment 346186View attachment 346187
How long can you work in those temps? How about build a wood stove with ducting to blow warm air on your hands while you work?Yes I work outside. In winter when its cold I can't work too long because my fingers freeze. and lately its been around -20°C to -30°C so the project hasn't progressed very fast.
Maybe 30-60min, depending what I'm doing and can I use gloves. Then I need to take little break. That is pretty interesting ideaHow long can you work in those temps? How about build a wood stove with ducting to blow warm air on your hands while you work?
Yes thats what I meant. I used 34.5mm inner diameter tube for the bottom bracket, but 33mm would be probably right size. Bearings fits good and firmly. I have mini metal lathe what I used to make the bearing fittings.I assume you mean the threads only cut a small amount into the tube, so you should have used a smaller tube. What did you use and what would you use next time?
i see the swing arm bearing fits ok, what parts did you use for that? The arm I'm building is very similar and would appreciate any tips.
Thanks! I'm also excited to see how its going to ride. I like the 2WD idea, but the extra weight to front wouldn't be good.This is my kind of Tony Stark build... Eager to see the completed project!
Given the terrain, I would think about going 2WD. Excellent work; best of luck!
