I snipped all but the part relevant to my reply:
Sunder said:
25 Amp Circuit Breaker
• Maximum voltage 250VAC or 50VDC
which on a 48v system isn't going to be good.
If you have 48V system, keep in mind it is actually above 50V until it's pretty much dead, for many packs (depends on chemistry and number of cells). For my own 14s NMC pack, for instance, it's average voltage is around 54V or so, I think, and it's full charge is 58.4V.
That's not much above the max, but if you really want to stay within the CB's ratings, you'll need a higher voltage unit.
It only matters at all because that voltage is usually the limit at which it is *guaranteed* to break the arc across the contacts that can happen as high current is flowing at the instant it starts to disconnect. If it cant' break the arc, it doesn't work and you still have a short circuit, AND you have a plasma arc inside the breaker, too, which is VERY hot and almost certainly will start a fire if it goes on long enough. Whether it does will depend on other things, like whether your wires melt first, or the pack dies, or whatever caused the short burns thru and breaks the connection, etc.
I couldn't comment on the likelihood of it happening, but it's possible.
The same is true of a fuse, if it has a voltage rating, then that is why it has one--and why the AC rating is so much higher--because of the zero-crossing point of voltage in AC, which gives the breaker more of a chance to extinguish the arc with a smaller contact gap than with a DC voltage at the same conditions otherwise.
That said, I"m pretty sure my breaker isn't rated for anywhere near the voltage I have on it, but it is designed for DC. I can't read the markings anymore (worn off) so to find out what it 's ratings actually are I'd have to find the pics of it in the CB2 thread from a few years back when I got it and started using it. If I had a breaker rated for the voltage I use, I'd use it, though--I just don't happen to, and I can't usually go buy the things I should actually use, and have to make do with what I happen to have.
