j3tch1u
Output shaft Matex part #U75-907.
kfong said:Excellent, that was what I was envisioning for my Currie gearbox. The motor I have is longer, so I was planning to put the gear box along side it, with a chain or belt to connect to it. How did you get the second stage connected to the first stage or are the matex gears setup to stack? Looks like I will need to create a connecting rod between my two stages and was thinking I might need to have bearings on that connecting rod. I like the cooling fins you put in. I'll have to remember that when I do mine.
12p3phPMDC said:the matex gears "mate" together--1 side is female and the other is maleit will not be easy to attach pulleys on these gearboxes--you will need to find someone to broach the pulley for you. you will also need bearings to support the sun gear. If you went single stage with that HXT it would still fit between the cranks.
kfong said:Thanks for the info, now I have a some idea of what I need to do. I still want to try putting them side by side. I like the setup as narrow to the frame as possible. I'll have to put bearing blocks for the sideloads and will use a freewheel and chain, but plans may still change as they always seem to do.
12p3phPMDC said:Thanks for posting those inspirational assembly pics!
12p3phPMDC said:So I would say the j3 two stage planetary drive is at 95% efficiency. :wink:
j3, awesome job on the battery assembly!!! 8)
bigmoose said:The cleanliness of your assembly and machine tools is impeccable! You must have worked in the nuclear industry or in medical implants?
cell_man said:Looking really good Ben, lovely workFancy making a few more of the battery packs
