Hello all,
First (though it's a long thread I've said this before probably) very cool work and ideas...
I read in the thread that the electromagnetic clutch wasn't cutting the mustard for you and just wouldn't hold under the torque of the drive/power...
In seeing the exploded model of that first incarnation (or maybe the second model) - the idea occoured to me - why not a hydrolic (use a brake MC) or pnuematic (don't ask me where from) - or even screw type friction clutch... I would think considering how mechanical disc brake calipers work by rotating their way out... you could perform a similar automated mechanism to engage a modified non metallic disc brake pad (or somthing similar) to a replaceable stainless steel faceplate.
This would cause the clutch to lock up... really it could be simplest if you simply daisy chain off existing brake cable pulls (if possible) with a ysplit and adjust so when you pull the brakes a little bit to engages the clutch... the more you engage, the more the clutch locks (actually it will lock pretty quick) which will enable your regen only when you pull the levers.
Someone may have already hit on this - the matex coupling as a stator was darn cool I must admit!
Can't wait to see it done!
-Mike
