hehehehe, you know what they say Matt, people in greenhouses etc :wink: roll
As steve sais we have the lovely drive down in the workshop but we found that the space behind the seatpost is a no go
it's a crying shame i tells ya, although it fits lovely i had underestimated how much the wheel comes in towrad the post under compression, ironically its the motor itself and not the pulley that gets squished so we are temporarily screwed
The easiest way out was to go back to 20" wheels, this would give us at least an inch of clearence at FULL compresion, however im totally against losing my 24's so that's not a plan i intend to follow.
Other solutions have been to make the stinker hard tail but again thats not favourite by a long shot.
These are the only two options to make the drive suitable for seatpost mounting - anything else means a downtube mount and here in lies our major headache, it's a damn shame too as the gb looks soooooo sweet mounted there.
This should explain the lack of posts, no update as yet you see.
my downtube is a major hurdle, it's round only near the bottom bracket then tapers upwards and soon becomes a square, very tricky to mount to.
The drive will have major forces on it which means the mounting has to be robust, i'm hoping that one of the other adopters will come up with something but i have the added problem of my battery box and i certainly dont want to mess with that if at all avoidable.
Bob is doing a fine job with the crank adapter and steve has done the pack to be 48v already but we are stalled on some other fronts too, we will need Richards board and also i need to order an esc program cable and have it sent to steve.
The guys have sent me some pics which illustrate the suspension problem, basically at full compression 20" is the largest wheel we will get in with the drive mounted to the post, for those who think dropping in the 20" is the answer you have to remember that i have run them on the stink before and they are not without their own issues, mainly clearence for the derailuer (why i went single speed) and the length of the crank arm (clearance to the ground),
It's a mofo to be sure but i'm away next week and so i can't see any progress happening any time soon.
This isn't all bad though as it will give me time to figure it out, as ever im the hardest person to please and it has to have form as well as funtion
I'll post up some pics later so you guys can see whats going on and all suggestions welcomed.
this is only an issue with the stinkers square tapered downtube, if it was round we wouldn't have an issue but it isn't and we need a new plan.
I dont intened to change my battery box one iota this time around so that makes the task all the harder but you guys know me by now,it has to be strong, it has to be pretty, D-termined to do it right!!!!!!
Sooooooo Mr S, whats happening with the PK?
Cheers,
D
