All these rear suspension set-ups are a compromise. They are more or less neutral to direct pedal input in one gear (sprocket combination) only. Either side of that you get compression or extension. Similarly, you need to set up the chainline between the gearbox output sprocket and the rear motor sprocket, so that the effect of the chain pull acting on the suspension is minimised..
