Hey Mitch,Kim,
its been two years or so since my beloved puma setup died and if truth be told my ride quality only went backwards with my first rc effort.
to mount a dual reduction is a total pita on a full susser, i'm barely managing to mount single stage so i dont want to further complicate the setup with an extra reduction, i just dont have the room for it. the kona was bought with a hub setup in mind,and was perfect for purpose - im trying to fit as best i can a better drive sytem but know its custom frame time to get things how i want them exactly so whatever i do with it now is solely to get at least few rides in this year that dont depress me
Im open to any drive suggestion but the route im persuing isn't very costly, bar the dual drive i have everything i need already an i have bought a few little bits that leave the door open for a few different setups, direct drive cog and adapter (thx thud) new rim for the dual drive so i can revert to normal wheel if i change my mind on setup.
I guess im at a point with it now where the kona will only get as good as a bike can that isn't custom built from the frame up.
i realise the new setup won't give me total indepence from the motor, as in if the pedals are in 2nd the motor is too but it doesnt matter as it does give me normal pedal gearing when im not using power, hopefully with unoticable/small drag.
the puma could easily outrun my pedaling but could be throttle modulated at low rpm smoothly through its range so i just applied the amount of gain i wanted at any given time, im not sure how close i can get to emulation with the rc kit?
Dual freewheel cranks would be nice to explore but i think all the freewheel shananagans should happen at the rear wheel, i keep having the image of a freewheeling cluster crop up at the moment.
Battery tech has crossed my mind a few times too, i realise things have moved on and i could have much more ah/bang for my buck but that said im still happy with my A123's so im not really thinking about upgrading, again custom frame time if i was to bother.
theres a little testing in this bike yet but im finding it hard to maintain interest when i know how much better i could do things if i was starting from scratch, i already said ,dont hold your breath :lol:
D
