AussieJester
1 TW
Well surely you have a metal file Deec only take a few minutes to resize a allen key to work :-S
KiM
KiM
deecanio said:Looking forward to seeing what matts up to, skyway tuffs were revered back in my bmx days im wondering what he's going to do with it? cant picture how he is using one?
D
deecanio said:Hi guys,
i get the pulley i just couldn't picture what he was going to do with a tuff to make it into a puley, mostly the mounting to the normal wheel?
no reduction will be ineteresting to see unfold, if he had a 150t he'd need a 10 on the motor, that would take some tesioning to get the bite required to drive i would have thought?
D
mwkeefer said:But D...
How can increasing top end (once moving) by 1.73 : 1 be bad or
how can increasing low end torque 1.73:1 be bad?
-Mike
deecanio said:Cough, cough, cough, so dusty here.
hi all,
So i recieved a packag of love from our cousins across the pond and everything is looking MUCH better![]()
first things first tho,In order to get running i need a wider bb- does anyone know where i can order a wide bb that fits a 68mm shell?
at the moment there is this http://www.sickbikeparts.com/catalog/product_info.php?products_id=107&osCsid=63783c04f426414fb8104aa8d79368a7
which is 15mm, that would do the trick i suspect but i cant find what size shell it fits, at the moment i have a splined 128mm which is just too short to run my belt down the inside of the crank (i'll post of some pics of my setup for this year once i get my pc working properly, but im desperate to order the bb no so i know i can carry on with the build now - im not bothered if its splined, square taper or whatever, just needs to fit a 68/73mm bb.
Secondly, i need to order a gt belt, can you guys advise how i order it? im guessing that i need to get some string and find out the lentgh i need? is that how it works? UK site would be best for me but as the bb will prolly come from the US no biggy.
Oh thirdly, a dumb question but can someone tell me how i wire up the 3220? six wire 3 blue/3black - because they are not sensored can you just connect them up in any order? im guessing i need to use the black wires?
HELP!!!!!
D
recumpence said:Deec,
Kim,
Wait till you see the two hand made, prototype motors I have sitting on my bench to be wound. You will promptly drool on your keyboard and mess yourself requiring much person hygienic attention.![]()
Nuff said.............
Matt
PowerGrip GT3. I get mine from these guys http://www.beeline.co.uk/gates-drive-belts.aspx They will split off belts to any width you like.deecanio said:oh belts!! - how do i measure up to get the right size and do you know any uk vendors? i only know they are gt(2)? belts, can someone steer me
deecanio said:i also quite like the short stroke (insert joke here)
