olaf-lampe said:IIRC the timing advance is depending on momentary RPM and load: the higher the RPM the more timing advance is necessary for the best output.
I believe the sensored infineons may have an auto-advance algorithm, because I felt some small vibrations comming from the motor under certain conditions and after a while they're gone. Seems it takes a bit time to find the right 'commutation angle'
The worst thing is too much advance, it's heating up the motor and controller.
-Olaf
Just finished reading the paper from Krumpi which give me wild ideas, given a non auto advancing controller like mine, I think we could have a very advanced fix hall sensor and separate controller to introduce timing delays, which then could dynamically changing the delays based on RPM 8)
