Rix said:
if I recall correctly, your axle one brake/phasewire side was supporting all the weight after the axle on the drive side shit the bed. Then you had someone make a HUGE axle for you. Is that right?
Yeah bad regen settings and a slightly flared drop out from a previous failure with no pinch bolts doomed me. Once I fixed the issue even the weaker H40 axle didnt break under 12kw.
And yeah, the drive side ate it and I managed to complete the lap with the motor only held to the frame by the other half of the axle. Pretty impressive. That motor is semi retired at the moment, still sitting on my old raptor with a dead battery. I blame the arrival of the FLX frames, those bikes are now dominating my time, building, testing new motors, etc. Gotta have a working high powered example of each. Good problem to have
One4torque, if you reckon the alpha is light weight you should try the beta, it's nearly half the weight again depending on how you set it up. With single crown forks and a lighter motor is't super nimble. I got mine finished off and going on the weekend and I'm really loving it! Totally an electric bicycle, not a light / cross over electric motorcycle 8)
I dont want to spam FLX stuff too much in the stealth thread but given their common pedigree I'll slip this one in
