stritzky
- Joined
- Nov 8, 2013
- Messages
- 346
Bexxer said:I found the culprit, chased the problem back to the rear brake disc and found a screw had worked its way loose and shredded the wires, hence pulled connectors apart. Surely these screws should have been torqued at assembly. Gah!
I'm Glad you found the cause of the problem. Use some Locktite when you torge them up again. And TV the Hal Sensors can also be broken by too much heat. Been there done that. But if the shuttering stil continues after you have fixed the wires, And there is nothing wrong with the wiring. Then you need to change the hal sensors. They dont seen to like shorting out.
