Hm, strange. Sure, that you are on the right branch on CubeIDE?!
yepp was my first use ... so i checked more times everything is right
Hm, I don't know, if DownG is not compatible with a certain dashboard firmware version, perhaps better ask at scooterhacking.org for the compatibility issue....
they can't help .... have to wait for stlink :\
und weil du deutscher bist ..... er kommt ja mittwoch da flash ich wieder rum
du könntest aber mal so nett sein und max settings für nen m365 classic posten
die werte scheinen ja anders interpretiert zu werden wie in den gehackten firms
also meine settings für 1.3.8 (botox)
DRV138 kers_min_speed=45.0 normal_max_speed=35 eco_max_speed=21 motor_start_speed=3.0 motor_power_constant=33000 instant_eco_switch=on russian_throttle=on remove_hard_speed_limit=on wheel_speed_const=33
und xiaogen 2.0.5
alt_throttle_on=1
smoothness=0
throttle_type=5
throttle_on_cruise=1
motor_start_speed_on=1
motor_start_speed=3
cruise_control_delay_on=0
cruise_control_delay=0
toggle_cruise_on=1
toggle_cruise_type=1
toggle_cruise_pause=100
toggle_cruise_spd=1
toggle_cruise_start_speed=25
toggle_cruise_value=20
toggle_cruise_delay=50
throttle_step_on=1
s_throttle_step=600
d_throttle_step=300
eco_throttle_step=300
cruise_control_sens_on=1
cruise_control_sens=25
brake_lever_par=1
brake_lever_limit=125
brake_min_current=1000
brake_max_current=40000
brake_step_on=1
s_brake_step=600
d_brake_step=600
eco_brake_step=600
kers_min_speed_on=1
kers_min_speed=60
anticlonk=1
kers_multip_on=0
kers_multip=0
kers_by_mode_on=0
kers_by_mode_eco=6
kers_by_mode_d=12
kers_by_mode_s=20
kers_off_switch=1
s_max_speed_on=1
s_max_speed=55
d_max_speed_on=1
d_max_speed=25
eco_max_speed_on=1
eco_max_speed=18
alt_speed_limits_on=0
alt_lim_cond=0
s_max_speed2=45
d_max_speed2=24
eco_max_speed2=18
s_main_limit_on=1
s_main_limit=22000
eco_d_main_limit_on=1
eco_d_main_limit=11000
s_currents=1
s_max_battery_current=22000
d_currents=1
d_max_battery_current=11000
eco_currents=1
eco_max_battery_current=8000
min_temp_limit_on=1
min_temp_limit=-10
max_temp_limit_on=1
max_temp_limit=65
voltage_limit_on=1
voltage_limit=32
remove_power_reduce=0
mode_to_turn_off_cruise_on=0
mode_to_turn_off_cruise_type=1
mode_to_turn_off_cruise_set=2
cruise_on_all_throttle_on=1
skip_cruise_max_throttle=1
boot_with_eco=0
skip_d_s=0
overvoltage_limit_on=1
overvoltage_limit=55
remove_charg_mode=0
baud_rate=0
no_bms_data_on=1
no_bms_brake=1
no_bms_min_temp=1
no_bms_max_temp=1
no_bms_volt=1
no_bms_cap=1
no_bms_error=1
no_bms_full_battery=1
shutdown_time_on=0
shutdown_time=0
lock_time_on=0
lock_time=0
no_lock_shutdown=1
postcharge_time_on=1
postcharge_time=600
postcharge_time2_on=1
postcharge_time2=300
cruise_beep_on=1
cruise_beep=0
mode_beep_on=1
s_beep=0
d_beep=0
eco_beep=0
charge_in_on=1
charge_in=0
charge_out_on=1
charge_out=0
turn_off_on=1
turn_off=0
charge_end_on=0
back_flash_freq_on=1
back_flash_freq=1
no_kers_flash=1
stop_beep_on=0
stop_beep_value=52
battery_beep_on=0
battery_beep_value=62
predicted_distance_on=1
eco_distance=30
d_distance=25
s_distance=20
ten_wheels_fix=0
ten_wheels_mult=0
strobo_on=0
strobo_spd=0
strobo_stop=1
strobo_fst_on=0
strobo_fst_off=8
strobo_scd_on=16
strobo_scd_off=24
strobo_reset=128
spd_chrg_swap_on=0
spd_chrg_mode_on=1
spd_chrg_mode=1
spd_chrg_set=0
spd_chrg_stop=1
show_param_on=0
show_param_time=12
show_param_type=0
drv_max_temp_on=1
drv_max_temp=90
boot_with_headlight=0
ext_err14=1
ext_err15=1
err_shd_time=1
swap_main_button=0
enable_wr_reg=1
