Bengy22
- Joined
- Dec 31, 2019
- Messages
- 201
I must say that is one of the cleanest non-ebike frame builds I have seen before. When I first saw the bike I thought you didn't have a battery mounted. Really cool the are making frames with storage built into the frame now. For a cleaner battery cable can you route it down through the shock cavity? Seems like there might be enough room to not get in the way and would hide most of it. I do want to ask what made you want to go with a non-ebike frame instead of say a Dengfu e10? I'm guessing its something to do with the geo but with my light budget I've never really compared bikes geo's so I don't have the knowledge on what frame would be more modern or better etc. $2400 just for a frame makes my eyes water though :lol: I know the e10 is around $1000 new.
I do want to mention if you want a battery that can do more amps you can get Samsung 50s 5ah and 25a discharge. So the same capacity (should see a little bit more capacity due to not running the 50e's at the max discharge). Or you can wait for some new cells like the lgm58t or vapecell f58 which both offer 12.5a discharge and 5570mah and 5800mah. But both have yet to hit the hobbyist market from what I've seen. Those cells plus a water bottle extension means you could be pulling big amps and long rides. If you have a 3d printer you could always print a housing to match the lines of the bike and mount to the bottle mounts, could look clean and fix a decent amount of cells extra. And you also might be able to buy that slower reduction from cyc separately, send them a email.
And nice 500w will get you moving good when you also have gears, now think of 1500w :lol: Does the cyc not allow you to customize the wattage of each pas level?
