torqueboards
You need to turn on your Nunchuck. The beep means the ESC cannot find your controller.
Your controller won't work if it's not on
duuude... that's already 3.6kW assuming you run on 7s battery, for sure you need something like motorbiker/superman clothes at that pace!okp said:... I have not been more than 125A maximum...
beetbocks said:im trying not to laugh at the 'superman' flight but i bet it was funny to see...lol.. ( i can laugh now your ok) i bet you wish your mate was following with a go-pro..that would have been a sure hit on Youtube...
well in my experience when the motors are cut by the ESC they dont stop dead but just stop being powered and so it seems like there been braked..as your not ready for the power stall...and its the motor resistance that brakes you...
so as i say best to keep everything as simple as possible on the setup- which i see you have already done..
get rid of nunchuck - which you have.
check all wire connections.
set to soft acc- and accept the lower speed..if i were you..
i don't see the bullets being a problem..its more about wire thickness if anything..
yes losing signal can cause braking and acceleration when not wanted..so its a big contributor..
made_in_the_alps_legacy said:duuude... that's already 3.6kW assuming you run on 7s battery, for sure you need something like motorbiker/superman clothes at that pace!okp said:... I have not been more than 125A maximum...![]()
