First of all, excuse my poor english. I red a lot on this forum about friction bike before daring undertaking anything.
I want to add a friction motor to my touring bike. I tested a friction kit and found that 100 - 250 Watt is enough. The motor will be on the front rack. All this has to be lightweight and easy to fix (or throw away) . I must be able to keep the panniers on the front rack.
Motor brushless outrunner 6354 180KV 24Volts ...rated 1500W ( wich I doubt...but don't care ) 0.6kg
Controller : brain power KSLG 794 (should do the job) 0.2kg
LCD-S866
PAS left pedal 12 magnets. I had to change the bottom bracket (axle was too short).
No throttle, no Hall sensor on the motor.... keep it simple.
Battery will be à 7S3P , the motor is used only when it climbs. As this setting adds around 2.5kg and induces no drag, on the flat I am able to pedal.
The result is ... ugly, crappy.... But it works (in my workshop with a small power supply) it is cheap, easy to fix.
The lever on the stem allows the motor to engage and disengage. No sanding belt around the motor, will add some if it slips.
I will try to answer any question about this very low level prototype.
Joël UGHETTO
If
LCD-S866
Joël UGHETTO
If
