I did 54 yesterday, not even sure if maxed out, but I want it to go slower.Don't overthink this whole build to the point where you never get it done. If you are starting with a DH bike its already designed for stability at higher speeds. A 24" wheel can be a great option. They are a bit more durable and keep the hub motor a little happier than a larger wheel. A 24" rear with a 26" up front gives you a little bit of free head tube slackening. If you use a modern tapered fork you will get a little more slackening with the external lower headset bearing.
Remember all of it can be changed in the future. Something being less than ideal beats a pile of parts sitting in your workshop any day.
You could chase your mind around in circles all day deciding between 65 and 66 degrees of head angle and someone would show up and try to convince you that modern bikes handle so much better than a a decade old frame and you are back to square one.
I know you want to do it right and optimize everything but its always relative and subjective. Get enough parts together to go ride it and then perfect your design. Suspension travel is adjustable. Fork lengths are adjustable. Hub motors can always be relaced to different wheels.
We all start out chasing some speed number we have in our head but the novelty quickly wears off. My bike will go 50mph and I don't remember the last time I was out of the 30s. Going over 40 on a bicycle never really feels calm and safe in my opinion.
It's violent, have to spin the cranks real fast just to get it to go, and then it's not gentle.
Dropping the chainring size hopefully helps.
