If I can't shim it into place, I'll take it into the local bike shop and ask what they can do by adjusting the spokes. I need to learn how to build wheels eventually, so my next wheel I might just build in order to finally start the learning curve.
The wheel is already built. If it’s true, then you can do it yourself. All you need is a good spoke wrench (the spokes will be tight, so you want good fitting quality spoke wrench) and ruler, using your bike frame as the truing stand. Just go slowly. And you’ll feel more confident about lacing your own wheel in the future. When I was a kid, we would launch our stingrays off big dirt hills down by the river. We all had to learn how to adjust the warped rims enough to keep them from rubbing on the frame. Tighten one side, loosen the other.
If you ask ChatGPT using actual measurements for you hub diameter it can calculate pretty closely how many turns it will take, but after the below, I just asked about a large diameter hub motor, and it said around 3/4 of a turn. If you need to reddish more than about 1/4”, you’ll need new spokes.
Here’s what I asked ChatGPT (without mentioning the large diameter hub). It looked right, but saved me having to type lol.
Directions for redishing a 36 spoke bicycle rim by 1/8”
Redishing a bicycle rim by 1/8" (about 3.2 mm) means shifting the rim slightly laterally so it is centered relative to the hub. This is usually done when the hub or frame spacing is slightly off or after wheel repairs. Here’s a detailed step-by-step guide:
Tools Needed
Truing stand (or the bike frame if necessary)
Spoke wrench (correct size for your nipples)
Marker or tape
Measuring caliper or ruler
Patience and steady hands
Step 1: Determine the Current Dish
Mount the wheel in a truing stand or on the bike.
Use a dishing tool or a ruler to check how far the rim is from being centered over the hub.
Note which side the rim needs to move toward (left or right).
Step 2: Prepare the Wheel
Identify the left and right spokes (typically the non-drive and drive side on rear wheels).
Decide how much lateral shift is needed. For 1/8” (~3.2 mm), the adjustment will be small, so each spoke moves only slightly.
Step 3: Adjust Spokes
To move the rim toward the right:
Tighten the right-side spokes a small amount (clockwise, ¼ turn at a time).
Loosen the left-side spokes by the same amount (counterclockwise).
To move the rim toward the left: do the opposite.
Tip: Make adjustments gradually. For a 36-spoke wheel, small incremental turns (¼ to ½ turn per spoke) are safer.
Step 4: Check and Repeat
After each round of adjustments, spin the wheel and check alignment in the truing stand.
Measure the dish with the tool after each adjustment to see how close you are to the 1/8” shift.
Alternate between tensioning spokes and checking lateral position until the rim is centered.
Step 5: True the Wheel
After the rim is properly dished, check for lateral trueness (side-to-side wobble) and radial trueness (roundness).
Make small fine adjustments to individual spokes as needed to ensure the wheel spins straight.
Step 6: Check Spoke Tension
Even after the rim is centered, make sure all spokes are evenly tensioned.
Uneven tension can lead to premature failure.
Pro Tip: For a 36-spoke wheel needing only 1/8" lateral shift, you may only need to adjust every 2–3 spokes slightly rather than all spokes, but spreading adjustments evenly can reduce stress on the rim and hub.
If you want, I can make a precise table showing how many turns per spoke for a 36-spoke wheel to achieve a 1/8" dish shift, so you don’t have to guess. This works well for small adjustments.
Do you want me to make that table?
