torqueboards said:Looks nice! Is it anodized or powder coat? Kind of looks like powder coat.
torqueboards said:One thing I noticed though because it's only 2 piece bolt on. It's a PITA to adjust the belt tension by removing the wheel every time.
777arc said:torqueboards said:One thing I noticed though because it's only 2 piece bolt on. It's a PITA to adjust the belt tension by removing the wheel every time.
So true
bandaro said:For the image/setup above, couldn't one put all 4 screws in loosely, get belt tension, tighten the outer screw, remove wheel, tighten the rest, replace wheel? Or is that what you do anyway, and removing the wheel one extra time is what you are trying to avoid?
Alternatively, there *might* be enough room to fit a spanner type screw driver on while the wheel is still in place, if you have one... Or buy a cheapie screwdriver and bend it like a can wheel nut wrench? Or use allen head bolt. Allen heads get nice and tight easily.
torqueboards said:Looks great! How do you charge your packs on that setup?
What PSI are you inflating at on those 6x2? I'll have to get a set and swap it with the rims I got of yours.
torqueboards said:psychotiller - I bought those 6x2 Matco.. Those tires are nice and thick..
I can run over little kids with those things.
beetbocks said:great idea mate..i like the adjust-ability and ease of manufacture....
sl33py said:Nicely done!
I've been thinking of using kydex for my battery enclosures for a while now! Easy, cheap materials, somewhat self healing and will take a beating to protect batteries (also slides well if scraped). I've not built a vacuum table yet, but do have the nicer press to form with.
Couple questions - what thickness are you using and can you share your forming setup? Also, in the first pic you have a large toggle switch - how was that wired? I wanted to do the same for my on/off switch, but don't know if it will handle the higher voltages and Amps. Planning on the inline XT-90 w/ anti spark instead, but curious how it worked. Also see it's not on the second version, so did it have issues or not work out?
What ESC is that? CC Mamba or XL2 perhaps?
Thanks. If too off topic maybe a separate thread on those questions? don't mean to hijack your mount thread. (*edit* - i did find your build thread. Impressive progression and skills to do it all yourself. Nice work. Curious on your vacuum setup still.)
