jonescg
Battery is starting to come together. I thought I'd use this as a good test bed for the copper-nickel-link method using these Molicell 21700 cells. So far so good. The machined polycarbonate was way too expensive for what it is, but it works well.
Soldering the nickel is OK, but I think I need to cool the whole plate down before attempting to solder the next one. Otherwise it all gets too hot and the previously stuck bits melt and float away.
The end terminal solution is pretty elegant I think. I solder a brass nut to the underside of the copper tab and bolt the BMS to it. That way if the BMS ever needs to be bypassed for troubleshooting you can. I was going to say 'if the BMS needs replacing' but at that point, your battery is already toast. The recessed polycarbonate means all the terminations are internal to the top cover, so it's protected and secured from vibrations.
The BMS is a fraction too big to fit inside the space left at the top, but that's OK as I can machine out the inside of the polycarbonate capture plates to accommodate the BMS with room for the cables to go underneath. I don't have a mill, but I do have a drill press. Time to buy myself a cheap X-Y table and some end mill cutting tools. A Jacob's chuck will be fine for polycarb.
I conclude I need to buy a longer shifter cable for this lever :lol: I didn't find an 8-speed shifter, so it's really only comfortable for about 3 of them. That's fine, as the motor does all the work, and the lowest gear is what you need for riding up the hill with a flat battery. All others are for show.
