Brake said:
Use a SDHC card. RSDwriter.exe run on your computer and choose the mini-l.bin file for the locked version. Download everything from electrotransport.ru. Not sure if you can use the card again for anything else after its been formatted with the firmware. You only have to remove the top two screws to open the display enough to insert the card. Power it up and update. One thing I had to do, that they recommend on electrotransport, is to perform a full reset afterwards. Mine acted funny before I did that.
thanks, brake. really appreciate. i followed your steps and added some info (reposting here for myself)
- insert SD card in computer (format the SD card as FAT?)
- go to: http://adaptto.ru/firmware/
- Open the firmware version folder you'd like and download the version to your local drive.
- click and run: RSDWriter.exe
- make sure the SD card is recognized in the pull down (reinsert SD card if it's not displaying and click Oбновление to refresh.)
- click second button on right to browse to downloaded firmware file. (do not use mini-u.bin as it will be unlocked version and void the warranty. use this ONLY if you want to set higher than max current limits. you will no longer be able to use mini-l.bin as it's not possible to write the locked over the unlocked version.)
- click bottom right button and wait. this writes the firmware to the SD card. don't understand the messages. can someone translate these? i notice the computer will no longer ever recognize the SD card, so don't use a high capacity one!
- remove SD w/ new firmware from computer
- unscrew top mini-E/Max-E display screws and carefully open top to reveal SD card port
- insert SD card.
- power it up and follow instructions to update:
- Remove the SD card.
- Power off and on system.
- Go to Advanced Menu and do full system reset, and then reset all your settings manually, including autodetect.
i found that the display screws strip wicked easily. in fact i'm pretty sure two were already stripped. when i opened the display a crack, a bottom screw dropped out!
now i'm concerned about waterproofing it.
rewired axel's battery balance harness from 4x5s to 5x4s:
BMS works:
made a vid on how to use a reed switch for the eBrake:
[youtube]PlNwYSsmzMM[/youtube]
the jb weld got messy - the reed slipped before it dried so i had to redo it - so this is a bit embarrassing, but it's the UNDERSIDE of the lever...
also had a fun time riding around the mall with the fam watching parts of the july 4th parade:
and a selfie w/ charlie in the glow of the fireworks:
