dnmun
1 PW
that looks like 470R so just the one should be fine. that is 170mA initial surge so it may be too hard on the led but it should work. when the led turns off it is down to 2V anyway so there is no spark left.
like this: and if want you can make it so the main "switch" is a plug with the pre charge push button directly on it so you can use one hand on each plug instead of fumbling around with more switches and plugs than you have hands.GCinDC said:i've whipped up a diag of what i'm pretty sure nicobie suggests with the momentary switch, but, pendragon, did i need to create a third parallel line for the led, or can it be inline w/ the momentary switch as shown?pendragon8000 said:With the precharge a suggest adding a led. I have a high brightness one on my monster build, I put the mom switch on the plug so I grab it, the light goes on and fades out then I plug it in and let go. No sparksand cool led charge indicator.
Led +1k r in parallel with big 200 ohm 1/2 watt r
now that i look at it, the led is on no circuit, so that won't do...![]()
for the resistor, i happen to have 5 Watt 470 ohm Metal Oxide Film resistors which i used on previous precharge circuits, so one of them will be fine, right?
thanks, pendragon! i feel like i know your thumb a lot better after watching that in full screen. do you chew your nail by the way? :lol:pendragon8000 said:if want you can make it so the main "switch" is a plug...sorry for mumbling so much, its hard to tell how load to speak with the phone camera.
do you have a bms on it? if so, and you configure it to balance above a certain voltage, it'll balance all night long, and the bms board(s) get wicked hot! hence my concern.xenodius said:Since the adaptto has a nearly-zero-draw sleep mode I rarely unplug my pack, just when I pull it off to take up into the apartment for charging. Very handy, especially since the adaptto has a naster password lock when asleep. But I agree, precharge is a must.
GCinDC said:looks like the fender will have to be right over tire to do much good, unless i made it much bigger....
nice cresh. pretty soon you'll have to add the snorkel gear...Cresh said:Fenders close to both tires, I didn't get wet at all!
oh yeah, i forgot, i had the flu and was down for 5 days. :xnicobie said:No posts here from GC in 8 days?
