beast775
This is going to be my next wheel -hub..great work GCinDC LOOKS PHAT!
so busy. so tired. practically comatose at night after familial duties are over...dbaker said:how is the wheel coming?
GCinDC said:some vids in the can with it, but nothing up to my standards yet.
Rutiger said:how you can raise the standard of said toilet videos?! :lol:
what i mean, re the chestie gopro mount, the shots just aren't as dramatic as my low bike mounts which show the ground contours and make it look like i'm going much faster. i went down some stairs wearing the chestie and from that perspective, it looks like nothing...GCinDC said:nothing up to my standards yet.
doh! tell me about it... i really need a large screen adaptto! i got lasic about 7 years ago, and while it fixed my distance vision, it ruined my near vision - probably didn't help they over did me - and now seeing anything w/in 2' w/o reading glasses is hopeless.dbaker said:Turns out the problem I thought was an internal clutch issue was actually the chain falling off the chain ring. Inside the chain ring on the way in and outside the chain ring when trying to get home. my eyes are getting worse![]()
i bought a cromo but sold it a month later after i gave up trying to figure out how fit it with a disc on the frame. and i was pretty sure i'd kill myself. but i've often wished i had a cromotor.samoloh said:GCinDC I am a little confused maybe a missed something back in the thread, why are swapping out your cromotor for the vented crystalite?
GCinDC said:well, the gopro is waterproof! and have we really seen the toilet's perspective? maybe if it's positioned in the bottom of the bowl looking up through the water... then the question is whether to shoot a number one, or number two..![]()
GCinDC said:i bought a cromo but sold it a month later after i gave up trying to figure out how fit it with a disc on the frame. and i was pretty sure i'd kill myself. but i've often wished i had a cromotor.
fact is i've been running an hs35 (or three) on this dh comp almost since the beginning, which must be getting close to a couple years anyway.
and i ordered an h4080 in july and it arrived in november, and i'm just getting close to mounting it.
special order with all kinds of mixups, but stupid low price. and i wasn't in a hurry...samoloh said:What!!!! 5 months is a long time to wait.
hs35 can handles 6kw for 3 min before overheating, w/o vented sidecovers.samoloh said:How much power can the h4080 and hs35 handle without mods.
that's awesome. i was a bit afraid to watch at first, but the dude is funny.rodgah said:in the museum of old and new art (MONA) in Tasmania, Australia there is a toilet with such qualities.
no, but i need one!rodgah said:There is a large screen addapto greg?
ugh, more confusion. i had no idea there was a 3580! and this is the "hs3540" from ebikessf.com (35-38mph @ 72V 30-37A). i'll check again next time i pop it open, since those markings are really only what matters i guess...nicobie said:Going by pictures you have previously posted of one of the stators I think you have a 3580 and not a 3540. I'm pretty sure I saw 12x6 written on the stato
dbaker said:Thanks. Going with my Planet Bike ones with flaps...
http://www.amazon.com/Planet-Bike-Hardcore-Fender-Black/dp/B003GM309W/ref=sr_1_3?ie=UTF8&qid=1390226926&sr=8-3&keywords=planet+bike+fenders
I believe it is ok, as they are in closed box and the protective cover may change the color with tempereture.GCinDC said:ps. andrey, is it possible the burn marks are just from normal heating, and not nec an indication of water exposure?
i was trying to avoid re-autodetect, so i could swap motors easily. i made the B-G-Y hall connectors the same, and then tried various phase connections - because i wasn't sure the colors and found for the various phase combos caused the motor to:andreym said:As for the 4080 motor connection, try re-autodetect your new wheel and to compare KV change mode to SQAW from auto\sine - because in SINE mode it is possible that additional timings and OVS cause the speed difference.
sweet. i think the sd port on mine is internal, so i have to pop it open, right? i'm in no hurry as i'm leaving my bike inside most nights..and if you have problems with display freezing you can enable display heater...
Yes - at least unsrew 2 top screws and open one side a bit, as I usually do:GCinDC said:sweet. i think the sd port on mine is internal, so i have to pop it open, right? i'm in no hurry as i'm leaving my bike inside most nights..
It does not work this way - each motor have it`s own personal hall placement(they could be inserted a bit differently at another angle and so on, resulting in different settings requred for perfect operation, so at least you need to autodetect new motor, than write down the settings ( Angle corr., Ind timing ) also before that write down settings for old motor,GCinDC said:i was trying to avoid re-autodetect, so i could swap motors easily.
