Starting point:
KMX Typhoon trike, all 20" wheels and a Shimano Alfine 8-speed rear hub. The previous owner also upgraded the brakes to Avid BB7s instead of the stock BB5s.
I've been riding it around the Arkansas River Trail area in North Little Rock Arkansas. I'm a new cyclist, and disabled; I used to have to stop and rest getting over some of the bridges. In three months of weekly rides I can make it up all the ramps, but some take a lot of effort even in the lowest gear, which is literally a slow walking pace - I've had walkers pass me on the Big Dam Bridge.
I expect to improve, but there are two further problems: the trike is geared so low that even pedaling as fast as I can, I'm regularly passed by old ladies on uprights, gliding along with an occasional flick of the pedals. Literally. I'd like to go fast enough not to be a rolling obstacle. Also, my wife, who is also disabled, wants to come along sometimes, which will slow me down even more. I ordered some bits so I can weld up a trailer for her to ride in.
Since the primary purpose of the trike is still 'exercise', I wanted a PAS instead of a throttle, and since almost all my riding is on 'shared use' bike/pedestrian paths, I can't use a whole lot of speed. Just a bit faster overall, and some help up the steep parts.
After looking at the options on motors and drooling over the high-power bits, I ordered a Bafang 750w BBS02B kit, the optional gear sensor, and a nicer display than the default. Actually, the 500w would probably have been enough, but I persuaded myself I needed the 750.
I'm going with the 42-tooth chainring for now; I'll buy a larger one if I need it. From what I've read the Alfine hub should be okay with the BBS02B.
I had already ordered a rear brake kit for the trike. The front brakes were badly scored and made horrible grinding noises; I tried sanding them smooth, but it didn't last long. Hmm. 203mm rotors are about the same price as 160mm rotors. I ordered 203s and new caliper brackets. The old brake pads were metallic, which is what probably ate the rotors. I ordered plain 'resin' replacements. Brake bits started arriving yesterday; the motor kit should show up next week, and the gear sensor two weeks after that.
I plan to go with a 48v 20ah battery, but held off ordering one since the battery box looks long and skinny and all the battery pictures look short and fat. When I get my hands on the box I can measure the inside so I can be the battery I order will fit.
I'm still collecting parts for the trailer. Basically an "Atomic Zombie" Aurora delta trike, except I'll be using a bolt-on snout so I can swap the hitch part out for a headstock and front wheel in the future. I'll have to help the Mrs. get up from it, but she'll enjoy zipping along a few inches from the ground.
This will (hopefully) be a big yawner to the experienced e-bike builders, but I'm going to document it as I go along. Hopefully some other newbies will find it useful.
