speedmd said:
The tooth profile is clearly not like the GT. The GT has tooth walls do not go parallel toward the tip as on the HT. The pulley teeth look clearly more like the HT to me. Has anyone put a belt against it to see if the tooth on the belt bottoms out as in the red-lined outline.
I'm starting to think you're right, Doc. I did clamp a HTD on it and while the fit wasn't perfect, it wasn't far enough off to be a completely different belt type. It's a sloppy HTD with an odd flat bottom to the profile. It's all Thud's fault! He started this!
I just bought this pulley to check my own digital profile anyway. This pulley is only 19mm wide and I want a 23mm wide to run a 20 mm belt on. I'll make some subtle adjustments to the profile to make it fit the belt better and then have a prototype made.
