Chalo
100 TW
spinningmagnets said:My experience was in using these roller-clutch bearings at 1,000W using a 1/2-inch shaft. If they were "almost" strong enough...we could add a case-hardened shaft spacer to the stock GNG shaft and then use a larger roller-clutch bearing?
When I have used needle roller clutches (and needle roller bearings) on aluminum or unhardened steel shafts, I have bought hardened precision sleeves and affixed them to the softer shafts. That not only provides a suitable surface for the rollers, but also a larger radius through which to transmit torque. In the relatively low torque applications I was building for, I bonded the sleeves on. In this case, using a heavy press fit or a key would be a good idea.
